Old 11-16-2013, 08:26 AM   #11
You can buy calcium chloride in 50# for $17.87 at Home Depot and put in in small individual containers and set it out in several locations in the camper.
Old 11-16-2013, 09:30 PM   #12
fiddler63's Avatar
I hope this question goes in the right place. I have three or four of those driz-z-aire things in my 33 ft fifth wheel. Should I still keep the roof vents open (just a crack)? It doesn't seem logical to try to remove moisture from winter air continuously circulating thru trailer. Should I close those vents and use the driers, or crack the vents and forget about the driers?
fiddler63 is offline   Reply With Quote
Old 11-18-2013, 02:21 AM   #13
Just a member
kandl's Avatar
We employ four of the "driers" throughout the TT, which is sealed up tight. "Sealed up tight" is probably disingenuous because RV's are nowhere near what a R-2000 or high efficiency home might exhibit re air infiltration. I would suggest that there's more than enough air leakage through your RV so as to preclude having to crack any of the vents. Even so, we usually have a peek inside every three or so weeks, especially if we've been having some wild temperature swings.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 11-18-2013, 04:40 AM   #14
Zhanna's Avatar
We live too close to the coast to not have a dehumidifier. We keep it plugged in and running all the time.
2005 Dodge Ram 2500, 4x4
2017 Heritage Glen QBUD312
Zhanna is offline   Reply With Quote
Old 11-18-2013, 07:32 AM   #15
DDC
DDC's Avatar
Kitty litter works to!
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 11-20-2013, 10:41 AM   #16
Charcoal is used for adsorption of odors and some chemicals but I don't think it would do much for moisture.
SuwanneeDave is offline   Reply With Quote
Old 11-20-2013, 11:49 AM   #17
Iwannacamp's Avatar
IMHO. Charcoal is not sealed when you purchase it, therefore if you don't dehydrate it before you use it, I wouldn't think it would help much. My .02
Old 01-12-2014, 11:16 AM   #18
sonic2's Avatar
moisture ventilation mold winterization storage
DRI-Z-AIR¬ģ DEHUMIDIFIER - MOISTURE ABSORBER - MADE IN THE USA and Damp Rid is made in china . I buy American whenever I can.
This site from the EPA explains Moisture and Mold Prevention and Control Tips. Control moisture (humidity), good ventilation (air movement) and light.
I use Dri-Z-Air year round; in the summer I slightly open the vents; in the winter I leave the vents closed and leave all inside doors open to allow free air flow.
2014 Rockwood 8289WS - Goodyear Tires
2013 F150 crew 4x4 5.0L 3.73 6 1/2 bed
Supersprings & Timbren & B &W Turnoverball
Anderson Ultimate 5th Wheel Connection Hitch
sonic2 is offline   Reply With Quote
Old 01-12-2014, 11:48 AM   #19
BigTJohn's Avatar
Use the air driers in between times that you can open up the rig and let the humid, stale air out. Wait for a lo humidity day (we even get them in FL) and open up the rig, run the exhaust fan(s) for 20-30 min with a door or windows open (lube the seals while this is happening) and then close it all backup. Works well for us and there is no stale, humid/damp areas inside.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 01-12-2014, 11:50 AM   #20
Ford Idaho's Avatar
I checked the tub of Damp Rid on the kitchen counter a week ago when it was fairly cold here water was not frozen about 1/8th of a cup I would guess.
This is the first time I have use this stuff, I may or may not try something else later this year.
I like to try different stuff rather than getting stuck in a rut with the same-o lame-o.
