Monitor Panel
Hello. New owner here. I have a question regarding our Monitor/Command Center on our 2018 Cherokee Forrest River.
On our control panel there is a HTR switch on the lower left hand corner. I am assuming this is for the hot water heater. When the switch is off and not lit up,is the hot water heater using electric from hookups? I have hot water with out it being lit up. If I turn this switch to on and switch lit up will this use propane for the hot water heater?
