Old 06-16-2014, 01:15 PM   #1
Canonman's Avatar
More Leveling
There have now been a couple of occasions where my Camco Trileveler just doesn't give enough lift (3 7/8") to get the TT level side to side. Camco does not recommend stack blocks under the leveler for any added height either. Had this been a dirt campsite, I would have simply dug a pit for the high side wheels and worked it out from there. State Parks frown on digging hole in their asphalt
Looking for suggestions on what products there might be to get up to 6 to 8 inches of height without having to go to the lumberyard. I like the drive on ease of the Trileveler and have considered the Anderson unit but would only get 4" with their leveler. I'm looking for something "more"
Thanks for the help!
FR Wildwood 22 RKS
2007 1/2 Dodge 2500, Cummins 6.7
Retirement training completed
Currently enjoying second childhood
Canonman is offline   Reply With Quote
Old 06-16-2014, 02:04 PM   #2
Stg1's Avatar
I can't help with your issue. However, If I had to lift one side of my TT 6-8 inches, I think I would try to find a better campsite.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 06-16-2014, 02:12 PM   #3
Canonman's Avatar
I would normally agree. Sometimes you're just stuck with what you got. I was hoping for a graduated something that would from 0 to 8". Anderson Rapid Jack makes one for changing a tire but they suggest it's too long for a tandem axel, "To level wheels of single-axle trailers. simply place the small end of the jack under wheel and drive up until level. Please note - It will not work as a leveler for multi-axle trailers because the jack is too large to fit in between the tires.
FR Wildwood 22 RKS
Old 06-16-2014, 02:47 PM   #4
Fulltime family RVer
A buddy of mine cut a 4x4 or 6x6 at an angle and drives up on that to level his camper. But, you're asking for a lot with being up to 8" out of level.
I know that the Lynx Levelers only recommend that you go 4 or 5 blocks tall (e.g. 4" to 5").
I think if this were me (and I know you said you were against this idea), I'd be looking at wood with the edges cut and angles to make driving up on it easier. But even that is a heck of a lot of wood to carry- figuring your average two-by-whatever is only 1 1/2" thick. To get 8" you're looking at 5 stacked on top of each other. I'd want a ramp so that the bottom most layer is the longest and progressively smaller until both wheels are fully supported.
Good luck and let us know what you come up with! If you have pictures that show the asphalt that is that far out of level, I'd be curious to see it.
ependydad is online now   Reply With Quote
Old 06-16-2014, 03:16 PM   #5
Canonman's Avatar
Well, let me say first, the Utah state park reservations web site leaves something to be desired. It turns out I had reserved a site with a 30' driveway to a tent site. Found that out after we parked and got all settled. CG host was very gracious offered to bring blocks etc to try and help but by then I had DW convinced we'd be OK for the two nights we were staying. The rest of the CG was booked full so not many options. Last year we found a similar problem at the Great Basin NP. Again not much could be done.
Please don't send me to the "wood shed".
The suspension takes up a lot of the rise with these levelers so you're not really 8" off level. Still I'd like to have something on hand when we run into these situations since we don't usually go back to the same place multiple times and often are in Forest Service, National Park or State Park only semi improved camp grounds.
FR Wildwood 22 RKS
Old 06-16-2014, 03:25 PM   #6
Only thing to do is to carry several(4 or 5) 4' lengths of 2 x 6's or 8's and some Lynx blocks to use as ramps.
Old 06-16-2014, 03:33 PM   #7
Canonman's Avatar
Thanks OC I know you've been doing this a lot longer than I have, so maybe the simple is best approach is the way to go. I was just hoping for something like the Tri-Leveler just taller. Love the convenience of that thing but sometimes you just need "more"
Name:	Copy of IMG_3554.jpg
FR Wildwood 22 RKS
Old 06-16-2014, 03:47 PM   #8
Just bungee cord them to the back bumper and use the Tri-Leveler as the ramp.
Old 06-16-2014, 04:01 PM   #9
Canonman's Avatar
I wish I'd have taken a picture of the outfit a couple of sites away from ours. You'd have been proud of his ingenuity.
The guy must have been 4' off the ground at the tongue and 2' of blocks and rocks under the wheels. He used 2 packs of Lynx blocks (still in carrying case) and a couple 4x4's plus 1/2 a cord of firewood.
Looked like one of those swamp cabins down in the bayou.
I was worried we'd parked too close to an impending disaster. He pulled out early the next morning. Probably didn't have real peaceful sleep
FR Wildwood 22 RKS
Old 06-16-2014, 04:28 PM   #10
Kaadk's Avatar
I know you said you don't want to go the wood route, but if it were me, that's the way I'd be going.
I'd also be concerned about anything stacked that high shifting, so I'd probably work out a system of boards with holes drilled in them and a couple of lengths of rebar or pipe to act as a pin holding the boards together. I'd need several lengths to accommodate for each variation in height.
So, assuming an average 2x? is 1 1/2 inches high, and max required height of say 10 inches, I'd need to stack:
7 boards - 10.5"
6 boards - 9"
5 boards - 7.5"
4 boards - 6"
3 boards - 4.5"
Below that I'd just use my legos.
I'd make sure the top board was long enough to fit both wheels (plus chocks) and each board added below would be progressively longer to provide the ramp. I'd then stack them up the way I expect to have them when parking, and drill straight down at least two holes (though I'd probably go more. Like every 10" or so.) Next, put rebar in the hole and cut to be flush.
Next, I'd remove a bottom board, and cut new pieces of rebar for that height. Repeating for each of the 5 possible heights. If I was a welder, I'd put a plate on each rebar to keep it flush with the bottom board, but I'm not so most likely that's where I would have left it.
If I really wanted to get fancy, I'd put a sill around the top board to provide a kind of 'wheel guide' to try to help prevent the wheels from slipping off the sides as well.
Of course, since I don't camp in these kinds of locations (actually you can't even find anything like that here) this was more just a design exercise.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
leveling
