Old 08-04-2015, 05:42 PM   #1
Motor home --- power while on-the-road. I own a bumper-pull RV, but we are leasing a
1. Is the generator necessary to run the motor home a/c and/or fridge while traveling?
2. How much fuel will I be using by running the generator in this manner?
Any tip, secrets or suggestions would probably bring back some color to my knuckles while driving.
Thank you in advance.
Larry Tiner is offline   Reply With Quote
Old 08-04-2015, 05:56 PM   #2
The generator must run in order to use a/c while driving. The fridge will run off propane unless the generator is running while driving. Very little fuel is consumed by the generator; however, when your gas tank gets to 1/4 full, the generator will no longer run. Hope this helps!
SkipnTerri is offline   Reply With Quote
Old 08-04-2015, 08:23 PM   #3
SkipnTerri, thanks! Wasn't aware there was still propane to the fridge. Big help!
Old 08-05-2015, 06:57 AM   #4
Santabobswife's Avatar
Just remember that the propane will be on until you turn it off.
Santabobswife
Bob, Diane & Snoopy
2018 3050s Sunseeker
Santabobswife is offline   Reply With Quote
Old 08-05-2015, 11:56 AM   #5
The generator will use about 3/4 gallon per hour at fulload.
dunk05 is offline   Reply With Quote
Old 08-05-2015, 11:58 AM   #6
If it a diesel generator it will probably use only 1 to 2 gallons per hour. As far as the white knuckle driving goes, just sit back, relax and enjoy the scenery.
poppoplou is offline   Reply With Quote
Old 08-05-2015, 03:05 PM   #7
Thanks, each of you. ...and the tip about white knuckles...
Old 08-05-2015, 03:10 PM   #8
RudysWorld's Avatar
There are some residential fridges now in the newer MH's that do not run on propane. Double check to be sure. Ours runs on propane or electricity. We only run generator for a/c when temperatures are high +95 or when we have grands riding with us, otherwise dash a/c is sufficient to cool us.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 08-05-2015, 03:12 PM   #9
Refrigerator should be able to run on propane. If so it uses very little.
Myrle is offline   Reply With Quote
power
