Old 08-15-2016, 09:43 AM   #11
Restcure's Avatar
Originally Posted by WolfWhistle View Post
Dunno, but aluminum anode in WH can smell like sulphur. Check the battery like was mentioned
Make sure the P traps are full as well... shower?
WW
For a while we had a big stink in our TT after it was moved. We suspected the toilet but eventually learned it was the shower. The P-traps are often small and can dry out. Even flushed grey tanks stink - REALLY stink - so we learned to keep the plug in the shower when it was not in use.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 08-15-2016, 09:51 AM   #12
DFW Rusty's Avatar
Originally Posted by kthoms View Post
Ok thanks, I'll try adding water first. The battery does have caps that come off but I can't see the level unless I take it out (I'm assuming). The batteries are under the stairs going into the motorhome from the main door
If I remember right, on my old MH on the coach batteries there was a line on the outside of the batter that was marked full, then you use a flash light and just kind of eye ball the level inside. When it's close to the same level as indicated on the outside your good, it's not an exact science when it comes to filling them, just don't fill them to the top.
2015 WildWood 27RKSS
2012 Ford F350 King Ranch FX4
DFW Rusty is offline   Reply With Quote
Old 08-15-2016, 09:52 AM   #13
Thanks will do, would rather not take them out if possible, have a busy night ahead of me.
kthoms is offline   Reply With Quote
Old 08-16-2016, 10:09 AM   #14
Just a quick update for the record...was really easy to top up the water levels, one battery was obviously dry. But it didn't matter, this morning the sulphur smell had returned with a vengeance. I hope this is under warranty, I've only had this thing for 2 and a half months!
Old 08-16-2016, 10:16 AM   #15
WolfWhistle's Avatar
You filled the p-traps including the shower? Is all the faucets closed? Could you have left some kind of food product in a space you forgot about?
Could it be chlorine smell because of the vinyl or materials in the new camper? I went into a closed up trailer at a dealer several month back and the chlorine (or whatever) gases burned my eyes and I had to make a hasty exit.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 08-16-2016, 10:27 AM   #16
Flybob's Avatar
If I understand you correctly, the smell was reduced when you disconnected the batteries and returned when you reconnected shore power. This would indicate a 12V problem. If the one battery was dry, it most likely shorted one or more cells and is causing the electrolyte to boil ( emitting sulfur smell). Take the battery out and take it to an automotive parts store to be load tested. If it is good then you could have a defective converter which is over charging. House batteries are usually installed by the dealer and if they were not properly filled to begin with, it could have caused the battery tp fail prematurely. Don't waste your time trying to charge a bad battery. It may show charged however once you put a load on it, it will fail.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-16-2016, 10:58 AM   #17
WW
Pretty sure it is the battery, the smell is coming straight from it..
Old 08-16-2016, 11:01 AM   #18
Thanks for the advice. At this point, I'm going directly to the dealer as it could be a number of things. They will call me back once they figure out my warranty....that doesn't make me feel really good about the place I bought from..
Old 08-16-2016, 11:08 AM   #19
"Once they figure out your warranty"??????
I thought you said it was only 2-1/2 months old?
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 08-16-2016, 11:29 AM   #20
I know. Not happy. It's a 2015 used motorhome but they gave me a warranty as if it was new, that's what they said!
motorhome
