Old 08-14-2016, 12:00 PM   #1
Motorhome STINKS
Wife took the motorhome for a trip, got back on Wednesday. Today I went put there and there is a massive stink that has developed while parked and plugged into shore power. She dumped both tanks and the smell doesn't seem to be coming from toliet or sink...help??
kthoms is offline   Reply With Quote
Old 08-14-2016, 12:16 PM   #2
A critter could have gotten in there and died. Might have to look for that. I would also check to make sure there is a water seal in the toilet. If the water wasn't turn on when the holding tanks were flushed, if some one checked the toilet no water would have been there to seal the valve on the toilet. It might be is simple is adding a cup of water into the toilet. Make sure the toilet valve isn't stuck slightly open. I have had that happen.
If that wasn't it You might have food going bad somewhere. Maybe something spilled in one of the storage places inside or even under the RV.
Good luck.
Wattsworld is offline   Reply With Quote
Old 08-14-2016, 12:19 PM   #3
Could it be the battery charging? They do seem warm to touch
Old 08-14-2016, 12:26 PM   #4
If it is a sulphur smell then it more than likely is the batteries overcharging. Be sure to check the water level.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 08-14-2016, 12:33 PM   #5
It is a sulphur smell. I bet they need water
Old 08-14-2016, 02:39 PM   #6
ilmor's Avatar
If that's the case you might be thinking about new batteries.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-15-2016, 07:52 AM   #7
So it is definitely the battery, smell is beyond strong. So I've unplugged the shore power and I've been doing some research and I'm not sure on somethings. Can the battery be saved by adding water or are they useless at this point? Do you think this would be covered by warranty? I only got the RV in June.
Sorry, newbie here and learning...
Old 08-15-2016, 08:25 AM   #8
DFW Rusty's Avatar
The battery should be under warranty. However, save yourself the trip to the shop and just ad some water to the battery first. Just do some homework before you go prying the caps/ lid of your battery off, you don't want to over fill it and some cheaper batteries the entire top comes off making it difficult to put back on and seal. Most good quality rv batteries have either round or square caps that you can pop off with easily.
2015 WildWood 27RKSS
2012 Ford F350 King Ranch FX4
DFW Rusty is offline   Reply With Quote
Old 08-15-2016, 08:28 AM   #9
Ok thanks, I'll try adding water first. The battery does have caps that come off but I can't see the level unless I take it out (I'm assuming). The batteries are under the stairs going into the motorhome from the main door
Old 08-15-2016, 08:41 AM   #10
WolfWhistle's Avatar
Dunno, but aluminum anode in WH can smell like sulphur. Check the battery like was mentioned
Make sure the P traps are full as well... shower?
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
motorhome
