Old 04-29-2012, 08:12 PM   #1
Mounting a rear hitch need advice
First off I realize it will void the frame warrenty i'm, looking to have some storage for my generators (Twin Hondas) and maybe some spare batteries on a cargo carrier box that goes into a reciever. I have read mounting it on the bumper itself is a no no. I took a pic of the way my frame is and how the current bumper is welded to the frame. I was gonna run a piece of steel across the camper just wondering if I should use the frame of the trailer (blue) or the bumper mounts (red) to weld my cross member too? Or should I ditch this whole idea altogether is this more trouble than it's worth?.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 04-29-2012, 08:19 PM   #2
Looking at the quality of the welding and the thin material, I would scrap the idea and look at the tongue. Re-arranging things there and maybe a rack as long as you watch the tongue wt and don't overload it or your tv.
The bumper has all it can take now with the spare tire bouncing around. A checklist should list checking the bumper for cracks around the mounting surface and where the red is welded to the blue in you pic.
Mine started cracking and I removed the pins in the spare tire rack and bolted it solid on each side and the bottom. Was going to weld the crack and never got around to it and towed it several thousand miles and the crack did not propagate further.
Old 04-29-2012, 08:25 PM   #3
Drinkin beer on the beach
Rod Johnson's Avatar
I'd mount it to the frame. I don't know how much room you have. But, if you could burn it to the frame and the bumper, it would make everything stronger.
Did you do the bumper yourself, or is it already part of the trailer?
I built a hitch bumper for one of my trucks, let me see if I can find some pics of the brackets...
New ones on the left, old ones on the right
This is from under the truck, looking back. They're bolted into the frame with (6) 1/2 inch grade 8 bolts.
The truck frame is 3/16" C channel. The bumper brackets are 3/16 or maybe 1/4 inch plate cut and welded together. And believe me, its on there.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 04-29-2012, 08:29 PM   #4
Wolfpacduramaxman
You can purchased a bolt on receiver (e-bay, amazon, ect) that fits the bumper and use a hitch cargo basket for hauling accessories, total investment $250. The hitch baskets are also available in aluminum, some models flip up for storing, and most hold up to 500#'s. Hope that helps, Goog.
Wolfpac Duramax
googmiester is offline   Reply With Quote
Old 04-29-2012, 08:42 PM   #5
Herk7769's Avatar
Goog,
I did this with my FAIL cargo tray mod. It lasted a week and the camper never left my driveway. Not a total disaster; I saved the "dog house" the generator lived in and learned why nothing should be attached to the bumper or frame of ultra light campers. Luckily not the hard way, as I could have watched my 2500 dollar generator; my blue boy; and my cargo tray sliding down the highway.
HAM CALLSIGN - KC3FFW
Old 04-29-2012, 08:47 PM   #6
Originally Posted by herk7769 View Post
Goog,
And into a poor unsuspecting soul following you. And Herk would be still paying the lawyers.
Old 04-29-2012, 09:16 PM   #7
JFM, your main frame I-beams actually look a lot beefier than some I have seen, so there may be hope.
It is the main frame members that you have to worry about, as they are the ones that carry any load you put on the rear. And as the top flange of the I-beams are tied together with the crossmembers that hold the floor of the camper (or at least they should be), it is the bottom I-beam flanges that need to be connected to keep them from flexing sideways under load, so that is where your crossmembers need to be located.
I would run as tall a rectangular tube as possible down the inside of both main frame I-beams. Looking at how much clearance you have above your bumper, you could construct a complete subframe and simply slide it into place, then weld it up solid. Is there anything between the frame rails at the back of the camper?
The only real issue is that if you want to put a fair amount of weight on the rear, the maximum bending moment will occur where the new subframe ends. So, in thory, the subframe should really extend far enough forward to find some kind of support, in this case being the suspension. When I do mine, I will go as far as the midpoint between the axles, as there is a lot of strength in that area.
If you simply beefed up the very rear bumper area, and installed crossmembers all the way to the axles, the I-beams could still fail, depending of course on the load applied.
Could you tell us exactly how thick the webbing and the flanges of the I-beams are, and how deep and wide are they? I could probably give you an idea how much weight they would support.
Old 04-29-2012, 09:37 PM   #8
It's a factory bumper. I was thinking of doing what your saying weld a solid beam across to each frame rail then attach to the bumper where the square reciever port would sit tying everything together. I just was not sure if the frame rails would hold lets say 125-175 lb area. I see Herk mentions not attaching to the bumper or frame of ultra lights. My unit is not an ultra light and the frame rails are I beams. Looks like the bumper on that truck is not going anywhere in fact that could probably pick the entire truck off the ground and hang by it.
Dunnc as for the tongue forget it im near the ceiling as it is in fact i remove my batteries and propane tanks off the nose when traveling to save the 220 lbs on the hitch and put that stuff in the front of the bed of the truck. I travel solo as well, im asking alot out of my 1/2 ton chassis with this unit. Tongue weight is the bigger issue than overall weight and was the reason for coming up with this idea in the 1st place. Figured a few pounds on the back would eliminate a few things going into the bed and may counter tongue weight in the process possibly a win win. Ram 2500 with a CTD would end all my woes .
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 04-29-2012, 09:47 PM   #9
I will take more pics tomorrow and take some measurments I like your idea of constructing the subframe and sliding it in. I need to see how far back inside the framerails I can go as you stated the further forward the better. As I stated above I'd be looking at putting 200 pounds as a maximum on this setup and the cargo rack is aluminum and rated for well beyond that.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 04-29-2012, 09:59 PM   #10
Dave_Monica's Avatar
Be careful when reducing the tongue weight...don't think you'd want to get it less than 10% of the camper's total weight.
Anyone that's been in that situation with light tongue weight will agree how evil the camper's handling can get!
Dave
