Old 07-13-2018, 11:07 AM   #1
"Mouse Proof" Travel Trailer??
Are there any travel trailers that are "mouse proof". I have fought this problem with my 2007 Rockwood 27ft. with a slide out. I can't see any points of entry from the bottom. I thought I had the problem solved when I removed the access on the front of the bathtub & found a mouse nest and that it wasn't sealed where the drain goes through the floor. But after sealing it last summer, I had just as many mice last winter as ever. I have even used spray foam around the slide out, but suspect that they still may be coming in around the slide. We want to purchase a new travel trailer in the future. I would like feedback on what others have found to be "mouse proof". We would still like a 27 - 32 ft. with a slide out.
johndeereman is offline   Reply With Quote
Old 07-13-2018, 11:20 AM   #2
NMWildcat's Avatar
Sorry. No such thing.
Scott and Liz - Southern NM
Old 07-13-2018, 11:28 AM   #3
GOODBYE SUIT - HELLO RV!!
All you can do is your due diligence and there are some great ideas on this forum for repelling mice, everything ranging from commercial pellets, to ultrasonic plug-ins to dryer sheets. I use ultrasonic plug-ins at my house with great results for insects; I have two in my camper as well. I've never had mice, either in the camper or at home, but I didn't have them before I started using ultrasonics, either, so I can't say that is why. But I do not see insects in either place .
HAPPIEST WHEN CAMPING!
2019 Rockwood 2104s ****
2017 Starcraft Satellite 16KS
2012 Jayco X23B Hybrid
2009 R-Vision C243S Hybrid
2006 Coleman Bayside PUP
HappyCamper1962 is offline   Reply With Quote
Old 07-13-2018, 11:36 AM   #4
I am in this camp also! Plus Never go around any "Disney Park" Total Mice! Youroo!!
Old 07-13-2018, 11:36 AM   #5
realebill's Avatar
I crawled under my camper and with a flashlight,I looked at all the places where a mouse could possibly get in. Areas around the wheels and axles was sealed,no entry there. Area around the tank drains,sealed,no entry there. Finally I looked at the area around the rear stabilizer jacks. There I found access to the frame and directly into the water heater compartment following the gas line. From there mice had access throughout the camper via the raceways for the water lines and gas lines. That meant access under the shower,vanity and kitchen...also into the stove. Solution,sealed off the access via the rear stabilizer jacks. Since I've sealed that off ( rodent proof spray foam) my mouse problem has ended.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 07-13-2018, 11:52 AM   #6
If your shore power cord is permanently attached to the TT and is pushed inside for storage, mice can follow the cord and get in. I've found drain pipes to be very poorly sealed, amounting to a huge mouse expressway into the TT. Removing drawers, access panels, etc, and sealing every opening I could find seems to keep the adorable little critters out.
Sorry, I'm not aware of any TT that claims to be rodent proof.
Tacky is offline   Reply With Quote
Old 07-13-2018, 05:02 PM   #7
007matman's Avatar
The best you can do is make sure to seal as much as possible. Open all the cupboards, cabinets, and storage bays. What I noticed is that the areas where HVAC, plumbing, and electrical enter/exit is usually big enough for the little buggers to get through.
I went around and sealed everything with spray foam. Also, items that contact the ground are frequent entry points like crawling up a cord, tire, etc. Spraying them.wuth some kind of rodent repellant helps.
The only sure fire way (and we've tried fresh cab and multiple others) was moth balls (which my family hates).
Last winter after sealing everything I could find and the moth balls I think we had one mouse. Pretty good I think.
007matman is offline   Reply With Quote
Old 07-13-2018, 05:15 PM   #8
Mr Towed's Avatar
Any suggestion for something you could spray on tires, etc, like you mention?
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Cats: Rhody and Hazy
Mr Towed is offline   Reply With Quote
Old 07-13-2018, 05:33 PM   #9
007matman's Avatar
We used this.. keep applying every few weeks.
Your friend has shared a link to a Home Depot product they think you would be interested in seeing:
Tomcat14 oz. Mouse and Rat Repellent Aerosol
https://www.homedepot.com/p/Tomcat-1...0605/302683092
Old 07-13-2018, 05:40 PM   #10
Just place cheap 'snap traps' around with peanut butter. They love peanut butter. Attrition will wear them out.
2018 DX3 37TS Sunset
rskeans is offline   Reply With Quote
roo, roof, trailer, travel, travel trailer
