Old 07-21-2019, 10:14 PM   #1
cag2515
Send a message via Yahoo to Cag2515
Need 6 volt batteries
Hi guys need for new 6 volt batteries for my 5th wheeler any recommendations out there
Cag2515 is offline   Reply With Quote
Old 07-21-2019, 10:19 PM   #2
cag2515
In need of 6 volt batteries
Hi I need for 6 volt batteries for my Cedar Creek Hathaway Edition can anybody help me out
Old 07-21-2019, 10:52 PM   #3
Coach
If you're looking for cheap and easy, Sam's Club or Costco are pretty good bang for your buck. If you're looking for higher end, that will turn in to a pretty long thread.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-21-2019, 11:01 PM   #4
cag2515
Thankyou
Old 07-22-2019, 12:29 AM   #5
B and B's Avatar
Trojan T105 are a very good choice. You can buy battery boxes on Amazon they will fit in. Here is what I did in my Landmark for two 6 volt with proper venting. Click image for larger version
Old 07-22-2019, 06:29 AM   #6
There are few batter mfg in the USA. SO any US made golf cart 6v battery shoud be fine. For bigger bucks the Trojan 6v , usually found on boats is a better product, but any batt needs to be operated properly.
A genuine deep cycle batt will have a "20" hour rating , finding a CCC or MCC rating means a starting or multi purpose batt which is NOT good for camping use , avoid them!!!!
If you boondock a SOC (state of charge) system should be installed as it is the ONLY "gas gauge" for battery charge that is easy to use.
My favorite,,,,there are many others.
TriMetric Battery Monitor - - Bogart Engineering
www.bogartengineering.com/products/trimetrics.html
○Measures battery % full, based on amp hour measurements for accurate information on state of charge (SOC). This method is more accurate than monitors ...
FFred is offline   Reply With Quote
Old 07-22-2019, 08:40 AM   #7
cag2515
Smile Thank you everybody
thank you to everybody who helped me with my battery problem well appreciate it to all have a great summer and be safe out there
Old 07-22-2019, 06:41 PM   #8
cag2515
Looking at a set of batteries by NPP 225 ah-need 4 to put in a series amazon.com $469 for 2
batteries
