Need Dinette Table Leg(s) Solution
Our TT has a u-shaped dinette. The stock base ends on the table’s underside and floor are plastic. There is a single leg in the center of the table. The table is unstable and wobbly. I’ve been looking into ideas to problem solve this. We need to be able to drop the table to convert to a bed too.
Will I notice any improvement in stability if I replace the plastic base ends with aluminum base ends?
What looks to be a good solution is a SNAP 2 Folding Table Base V-40. So far I’ve only found this item at one web-site and shipping cost almost matches the product’s price. I’m not sure if I want the added weight (65 lbs) as well. If I don’t find something that looks more promising, I might order the SNAP 2, regardless of shipping cost.
The Lagun mount looks good too, however it doesn’t appear there would be an easy way to drop the table for sleeping.
Any other options I should / could look at?
