Old 07-29-2016, 09:55 PM   #1
raptor's Avatar
Need help on RV Steel carport for FR MBS 2401R
Hi,
What is an adequate size on rv steel carport for FR MBS 2401R? I got a quote on a-frame vertical 14 gauges, leg height 11ft, width 12ft and length of 25ft for $2.100.00. Should I need more room than that cause RV is already 25ft long? Certified building cost more than no-certified. Does it need to be certified? It’s all newbie questions because I knew nothing.
raptor is offline   Reply With Quote
Old 07-29-2016, 10:02 PM   #2
Originally Posted by raptor View Post
Hi,
What is an adequate size on rv steel carport for FR MBS 2401R? I got a quote on a-frame vertical 14 gauges, leg height 11ft, width 12ft and length of 25ft for $2.100.00. Should I need more room than that cause RV is already 25ft long? Certified building cost more than no-certified. Does it need to be certified? Itís all newbie questions because I knew nothing. I will not know if I don't ask these questions.
Your building needs to be larger in All ways! You also need to check your Local Building Codes for the other answer! Youroo!!
Old 07-29-2016, 10:30 PM   #3
Usually Confused Member
emm-dee's Avatar
I paid $2,900 for a 20x40, 11' legs which gives me about 14 feet in the center. I park the TT towards the left side and have enough room to park the Ram alongside and even extend the awning. I don't have slideouts but if you park your unit toward the center 20 feet will probably allow extending the slideouts and awning.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-29-2016, 11:05 PM   #4
raptor's Avatar
The next size up is 12x30x12. emm-dee what ground preparation you did to be ready for your building?
Old 07-29-2016, 11:06 PM   #5
raptor's Avatar
Our ground is 90% potatoe size rocks.
Old 07-29-2016, 11:16 PM   #6
emm-dee's Avatar
Ground was pretty level to start with. It's Georgia Red Clay so that's some pretty hard stuff. Covered it with '5-7 gravel. The carport gets leveled (roof line) when built. I had about a ĺ inch overall drop between the slides. I just mixed up some concrete and poured two 18" x 5' pads for the trailer tires to rest on. Those pads are perfectly level with each other.
Biggest problem was digging a 125' trench from the barn to the carport to run electric (50 amp) and water.
Old 07-30-2016, 12:00 AM   #7
Hi,
I would be sure your width is ok also. They may put 4' braces on each leg
to roof (both sides) that will cut into your width somewhat. Shouldn't be a problem if you have good hgt.
James & Amy
2016 246RKS Freedom Exp.
2006 Toyota Sequoia
It's a nice night for an evening
woodpile is offline   Reply With Quote
Old 07-30-2016, 12:18 AM   #8
dannyabear's Avatar
You should go to 14' width and about 5' longer than your coach
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-30-2016, 12:35 AM   #9
raptor's Avatar
Thanks for all suggestions. I am going to check to see if I have enough clearance beside the house for 14x30x12 leg.
Old 07-30-2016, 01:07 PM   #10
Last week we had a 31x18x 14h installed with 3 panels on each side for $2800. Our 2401R fits under it with slides out nicely. The awning will go out if I park all the way to the side.
glb6 is offline   Reply With Quote
