01-04-2018, 09:29 AM
Need help. We are in a campground in Tifton GA on our way to 3 months in FL. We have a
Fridge and water heater
01-04-2018, 05:34 PM
Ok all my post didn’t show so here goes again. We are on our way to Fl from MI in the worst weather ever. 16 below actual. No water in the rig until we get to warmer weather. In Tifton GA I turn on the water and water heater. The fridg quit and the water heater won’t heat on electric or propane. I have check every fuse and breaker there is. Both the water heater and fridge are less than a year old in a 2007 RF Georgetown. I know there is someone smarter than me that can give me an idea.
01-04-2018, 05:35 PM
By the way fridge light is on and fault light is off.
01-04-2018, 05:40 PM
I am NOT trying to be smart&&. BUT, my furnace wouldn't come on and danged if I didn't have the 'dial' turned to the wrong propane bottle, the one that was OFF! Then my thermostat did stupid things, and I just powered it down and back on and it worked.
Next, I'd check my battery.
Past that, others need to chime in.
FROG AR-0019-242
01-04-2018, 05:56 PM
Not a bad thought however in a motor home there is only one and it’s half full. Also both should work on electric but don’t
01-04-2018, 06:06 PM
Have you tried to reset all the GFCI's in the RV?
Have you checked 12 and 120 voltage at the water heater and at the control board of the fridge?
Gotta go campin!
01-04-2018, 06:22 PM
Carknocker Family
If rv was winterized, to you put valves back into normal or is tank still bypassed? You burnt your element if the latter.
On fridge, I have had a glass fuses blow that was in the circuit board on back of fridge. Replaced and it started working.
All just suggestions, hope it helps
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
01-04-2018, 06:32 PM
I have not found gfi except kitchen and bath. I will look further. I know about the glass fusses at the board but haven’t checked them. That will be my next step
01-04-2018, 07:55 PM
I feel for you having to deal with that in -16 degrees. Good luck.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
01-04-2018, 09:43 PM
Is it -16 in Tifton, Ga.? Or did I misinterpret OP's post?
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
01-04-2018, 09:52 PM
mypalal51 , Is your propane leak detector turned on? My gas wouldn't work on anything if the propane leak detector was turned off.
Good luck!
01-04-2018, 10:13 PM
can you light a burner on the stove???
01-04-2018, 10:14 PM
Is there gas to stove? Assuming you have stove.
There was a post here a few weeks ago about filling lpg in the south and getting a higher blend of butane and trouble in cold weather because of freezing.
If you have worked around/checked most things then I start getting lost. I would assume the butane deal, bad regulator, bad valve/blockage. Did you try closing tank valve. Vent lines. Then reopen tank valve slowly?
2017 Puma 297RLSS
01-05-2018, 07:34 AM
It was -16 in central Illinois
01-05-2018, 07:36 AM
It’s on thanks
01-05-2018, 07:37 AM
The furnace is running fine
01-05-2018, 07:41 AM
Originally Posted by mypalal51
It’s on thanks
What was the problem?
It will help others with similar problems to know the fix.
01-05-2018, 08:03 AM
I would believe 16 F or even -16 C, but there is no way it was -16 F. I guess it depends on how you interpret “16 below actual,” which is kind of cryptic.
Gary
2017 Cedar Creek Silverback 37MBH
2008 Dodge Ram 3500 6.7L, DRW, 4.10 Rear end
01-05-2018, 08:22 AM
See OP’s post #14... central Illinois.
01-05-2018, 08:28 AM
X 2
1930 lbs CCC
2014 Jeep Rubicon JK
