Old 06-12-2015, 09:09 AM   #21
I have found that even on a flat surface the hitch occasionally won't release from the ball until I climb back into the truck and release the brake and put the tranny in gear. You want to make sure the rear wheels of the truck are on the ground though.
2015 Rockwood 2703ws
2013 Ford f-150 5.0 3.55
Rockwoodjoe is offline   Reply With Quote
Old 06-13-2015, 06:33 AM   #22
Wolverine 1945's Avatar
wpgman,,,
I never liked our setup,,, but could not find another way to level,,, used blocks & wood under the power jack + under the stablelizer legs which were out as far as they could go,,, then I would put a little weight on the legs,,, Did not look safe at all !!!
Our Flagstaff did not have leveling jacks,, they were only for support,,, do not remember what they were called ??? Good Luck & Be Safe !!!
Best to find another parking spot,,, We spent almost 2k for drive way extension,,, to have a level place to park MH !!!
Wolverine 1945 is offline   Reply With Quote
parking, trailer
