Old 08-13-2018, 06:25 PM   #41
JKVenero's Avatar
I carry around a 3 speed Hunter Bay floor fan that we call,” The Hurricane”.
JoJo the Retired PoPo
JKVenero is offline   Reply With Quote
Old 08-13-2018, 07:06 PM   #42
We carry 2 - 24” industrial fans. Put one on each side of the area under the awning. We are in south Louisiana and wouldn’t dare camp without them. We carry them in the back of the truck as we use them under our patio when not camping. Hey, it’s hot as hades down here!
Carol and Tommy
2018 Rockwood 2506S Mini Lite
Dozagirl is offline   Reply With Quote
Old 08-13-2018, 07:12 PM   #43
Saw this last weekend at Pennekamp...
DutchRv is offline   Reply With Quote
Old 08-13-2018, 07:23 PM   #44
Pig Sweat
Originally Posted by fella10 View Post
my first thought would be the 20" box fans already mentioned, ... they can sure move air, are certainly better priced, not an awkward shape so they should store easily, ... but I like "sweating like a pig", ... have said that all my life, cause my dad did, ... a couple of days ago, after repeating that, I realized I don't even know if pigs do sweat, but apparently it's a common phrase, ... thanks for the smile you've given me today, ...
No, pigs do not sweat. In hot weather, they love to wallow in the wet mud. That's how they cool down. I don't know where that saying came from.
Flash54 is offline   Reply With Quote
Old 08-13-2018, 07:32 PM   #45
We just purchased a tower fan and it works so well. It kept all the mosquitoes away and it kept us cooler while we sat outside, which we do most of the time while camping. One other benefit is how quiet it is. Here's the one we ordered from Amazon.
Lasko 4443 40" Hybrid Fan
lailap is offline   Reply With Quote
Old 08-13-2018, 07:44 PM   #46
Artic Cool fan. We don't go anywhere without one, but we usually camp in the desert. Works on Ryobi batteries. Has misters. Sits on 5 gallon bucket of you want misting. Available at the orange warehouse home store. About $80.
Everything written by this author is not claimed to be fact nor fiction and may be considered seriously altered depending on the libation being consumed at time of writ.
2012 FR Stealth 2714 Toyhauler.
2017 Ford F 250, 4x4, Super Cab, 8' bed, 6.2 gas motor.
Various Desert Toys including a Rzr XP Turbo.
ADVtraveller is offline   Reply With Quote
Old 08-13-2018, 08:06 PM   #47
Villagerjjm's Avatar
I have not seen a battery operated fan that can deliver a generous amount of air movement with the exception being one of the 12volt Dynamax vent fans. If you are looking for a nice compact fan that really moves air with a minimum amount of noise, check out the outdoor wall mount fan at Lowe's. You can mount it on your RV, and it is made for full weather exposure. Variable speed and it can rotate from side to side if you so desire.
Villagerjjm is offline   Reply With Quote
Old 08-13-2018, 08:33 PM   #48
I use a squirrel cage fan from a residential HVAC package. Works on 110v 15 amp plug. Moves a lot of air, is quiet, and is about the size of a bread box. Drawback is awkward positioning and no safety guards but a blessing on a hot day outside.
aerogoat is offline   Reply With Quote
Old 08-13-2018, 08:37 PM   #49
Lasko 12.25-in 3-Speed High Velocity Fan (or similar)
Got this a few years back when tent camping in the summer down in FL. Had seen a guy few spaces over with a nice, big RV sitting under his awning with the fan blowing at him. Thought he was wasting perfectly good AC inside, but liked his fan. Enough that we took a trip to the store and picked up the first one we saw. Now I use it to help blow the heat from the wood stove in the winter and circulate air at home. And then in the camping months, it is in the RV waiting to be used. Works really nice as quick cool down after setting up at a new site.
xlrnitrorv is offline   Reply With Quote
Old 08-13-2018, 08:38 PM   #50
We carry an oscillating fan with us, three speeds. It is helpful.
pamMJR is offline   Reply With Quote
Old 08-13-2018, 08:46 PM   #51
logspec1's Avatar
I have a wall mounted 16 inch fan with the bracket mounted under the awning. when we camp i just take the fan from the trailer and set it on the mounting bracket and plug it in. when we leave just take the fan down and put in the trailer. only thing outside is a small bracket.
Ken
2017 Rockwood 8329SS
2012 Ford F250 King Ranch
6.7 TD Super Crew
"Go Navy"
logspec1 is offline   Reply With Quote
Old 08-13-2018, 09:57 PM   #52
We bought one of these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's cheap as heck, both in quality and price, but it saved our bacon one night boondocking. Ours was wobbly due to the eccentric hub glued on crooked at the factory. That being said it moves a fair amount of air.
There are a few models/sellers/sizes. We plan to try a bigger one and make a suction cup bracket to hang under our awning. I used a spare motorcycle battery to run it, but i'd like to put a power plug of sorts on it.
howiez69 is offline   Reply With Quote
Old 08-13-2018, 10:02 PM   #53
larry2c's Avatar
We have had one of these for about 3 years. We dry camp a lot so having a fan that runs on its own battery is a big plus. If you're lucky enough to have a site with water, you don't have to run the pump and the battery will last several hours (with the pump, it's less than one hour).
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 08-14-2018, 07:45 AM   #54
This misting fan has worked well for us in the Texas summer.
As a wise man once said, "Wherever you go, there you are."
2020 Flagstaff Super Lite 26FKBS
2018 Ford F-150 Super Crew Platinum
Previously owned a 2018 Rockwood Roo 23IKSS
Aqualight is offline   Reply With Quote
Old 08-14-2018, 07:47 AM   #55
Originally Posted by Wiscampsin View Post
DW picked up a 3 speed 20" box fan at Walmart that we always take along. Lightweight, cheap, and does the job.
X2
Roberte52 is offline   Reply With Quote
Old 08-14-2018, 08:03 AM   #56
Frog-Toberfest Organizer
I use this fan https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
Electra glide is online now   Reply With Quote
Old 08-14-2018, 08:59 AM   #57
Is you have battery powered tool buybwhatever fan goes with your tool set.
I have Milwaukee so I have their fan.
My dad has DeWalt.
I actually like his better. No secondary cord needed to plug it in to 110. Just an extension cord. And it is variable speed.
Well worth the $100. We even take it on the boat with us.
calebj06 is offline   Reply With Quote
Old 08-14-2018, 09:06 AM   #58
Ditto what many have said - we bring one or two 20 inch box fans in hotter weather. Inexpensive, moves a lot of air, light weight...
Dave & Cindy
2015 Flagstaff MicroLite 21FBRS Sapphire Edition
1999 Chevy Silverado 2500
campkasten is offline   Reply With Quote
Old 08-14-2018, 09:41 AM   #59
Originally Posted by p40whk View Post
So I'm sitting under my awning this weekend sweating like a pig and I hear this noise over at another campsite. I look over and they had one of those huge warehouse type fans going and I was extremely jealous!
Not sure how they carried that big fan around but I thought if I could find one small enough to keep some air moving outside that would be great. Was wondering what others have in their arsenal?
Not sure if there's a battery powered fan that would do the job but I do have an external outlet I could plug into when I'm at a site with facilities. I was thinking one of those tower type fans would store well but not sure how well they perform.
https://www.walmart.com/ip/Stanley-H...ellow/21783277 Best fan you can get they are small lightweight and move a ton of air!! We use them in our band for outdoor gigs and then throw them in a bin we have for misc equipment. they're very tough. and we also put them up under TT where it's generally cooler. You can't go wrong with these
RobinDella is offline   Reply With Quote
Old 08-14-2018, 09:49 AM   #60
Originally Posted by owebe1 View Post
I personal like a squirrel cage I purchased at Sam's wholesale club .It's compact has two 110 outlets on the side and three speeds and moves a lot of air.
That's also what I use. Be hard to out perform it. It's high most places but Sams has it at 69. https://www.samsclub.com/sams/pivoti...lp_product_1_1
Simplewon is offline   Reply With Quote
door, fan
