Old 09-18-2012, 08:08 PM   #1
Need some info On Towing Two Different Rigs.
We are getting ready to enter a new world of towing in about 6 to 8 weeks. We ordered a new 2013 5th wheel 31 foot long, I have been towing a 29 foot Fleetwood TT for five years then went to a 34 foot 2006 8314ss Rockwood TT for the last 6 years or so.....The info I need is what should I exspect between towing two different types of campers this is the first time with a 5th wheel. I would the Pro's and Con's on both sides of the fence.....Now I will give a little more info.....
THE NEW CAMPER:
The 5th wheel dry weight is approx 7,465 lbs and fully loaded is approx 9,995 lbs, it is 31' 8" long.
The 5th wheel is a 2013 Open Range "Light" and the model is an LF297RLS, and we bought this at the Hershey RV Show. " A Great Deal With Extras"
MY TOW VEHICLE:
My tow vehicle is a 2008 Vortec Max Heavy Duty 1/2 ton Chevy Pick-Up, 6.0 gas engine, Heavy Duty 4 Speed Atomatic Transmission and a 4:10 Rear.
The bed on the truck is 6.5 feet and it has an extended cab.
The trucks tow capacity is rated at 10,500 lbs, it has the heavy duty tow package and electric brake controller all installed from the factory.
Any Info Would Be Great and Thanks in advance.
Old 09-18-2012, 08:36 PM   #2
You've said nothing about pin weight, so we don't know if payload is maxed.
If your fully loaded weight is correct, you'll be at the max tow capacity for your truck. It may be fine, but you won't know until you try it out. Many on here want recommend 15-20% reserve, but that may be a matter of personal preference.
If your pin weight is OK, then I'd reserve judgement until you've taken it for a tow. Could be an expensive gamble if it doesn't work out.
Good luck.
crasher is offline   Reply With Quote
Old 09-18-2012, 08:40 PM   #3
You are right, see I need help thanks....Hitch weight is..1,265
Old 09-25-2012, 09:37 AM   #4
Wanna Be Camper
SaskCampers's Avatar
The little info I can find on GM payload seems to indicate that unit has a payload of around 1855lbs so it would seem you should be OK
Extended Cab, Standard Box
Max Payload 4x2 1895 with 6.0L
Max Payload 4x4 1855 with 6.0L
Max Trailer 10,500 with 6.0L / 4.10 axle
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
