Old 03-22-2015, 08:18 PM   #11
Does the trailer sit level connected to the truck, on flat ground put a long level on the trailer floor and see where you sit. If you were too high at the hitch you could be transfering some weight forward.
2012 Dodge Ram 2500 Limited 4x4 ramboxes
2012 Chevy Tahoe
2011 Yamaha Venture
Wildwood 241QBXL
dacheedah is offline   Reply With Quote
Old 03-22-2015, 08:33 PM   #12
It is a inch higher than level at coupler but I can't get it any closer tried.
uhduh camping is offline   Reply With Quote
Old 03-22-2015, 08:42 PM   #13
Originally Posted by HONDAMAN174 View Post
You do have a large TT and a very nice one at that. If you really like the anderson you could get support brackets welded to your frame like these:
I used the Andersen on my 29' jay flight it never moved in the two years that I had that trailer. I also marked the brackets on both units to see if they move. they have not budged. I will weld them if they ever move the tiniest bit.
Old 03-23-2015, 12:48 PM   #14
Blog: RVroadtripper.com
hbillsmith's Avatar
When I was towing a TT with my Andersen, I wanted it more level so I traded the 6" hitch ball carrier for an 8". When flipped, I could drop the tongue another inch.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 03-23-2015, 02:11 PM   #15
My thoughts are if you are high you are taking weight from the front axle and putting it on your hitch. If you know someone with a lower hitch height you can test this easily, I was always taught if you pull off level, it's always better to be slightly low than above level with level being preferred.
2012 Chevy Tahoe
2011 Yamaha Venture
Wildwood 241QBXL
Old 03-23-2015, 02:57 PM   #16
I already have 8" drop drawbar. If I flip it the ball sits 4" higher but thanks.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
Old 03-23-2015, 03:18 PM   #17
Have you thought about seeing if you can replace the receiver with something rated higher? A new WDH is not going to solve your problem.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-23-2015, 04:32 PM   #18
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Well was trying to solve two problems lower tongue weight and more weight to front axle. If I get the tongue weight down, I will get more weight to front axle. Not a lot but some. I know WD won't change tongue weight. A different hitch doesn't help with cantilevered tongue weight on rear springs.
Hensley Arrow
Old 03-23-2015, 04:50 PM   #19
Would have a bit less coming off of the front axle with a lower tongue weight, but lowering the tongue weight by a significant amount is going to be difficult, if not impossible. The 240lbs light in the front would not be a major concern for me. Overloading the receiver would be. I'm 160 lbs light in the front and it doesn't affect a thing, that I can tell. Then again I loaded a full bed of firewood a couple of times (without trailer) which took way more than 160 off the front and I could notice a difference in handling. The way I look it is that pickups are designed to have a load in the bed and still function.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 03-23-2015, 04:53 PM   #20
Just put air bags on it and level it out and put the wt back on the front.
weight
