Old 04-25-2016, 05:14 PM   #1
New awning question
I believe the awning get on my Wildcat 323MK automatically drops down when it has collected too much water. My question involves the knobs on both arms. How do I use them? Tighten them, loose them? What?
Name:	ImageUploadedByForest River Forums1461622411.821438.jpg
ID:	106096   Click image for larger version
Name:	ImageUploadedByForest River Forums1461622431.509076.jpg
rogerkathy is offline   Reply With Quote
Old 04-25-2016, 05:26 PM   #2
nomad297's Avatar
If you tighten both of them, the awning will not dump the water. Only tighten one of them after you pull down some if you are trying to give your awning pitch to shed the water or tighten both of them after pulling both sides down if you are trying to lower the height of your awning.
Bruce
Old 04-25-2016, 05:30 PM   #3
crunchman12001's Avatar
I tighten mine, one side with a slight drop for rain run off. The auto dump feature will get you when least expect it. I think I get less bounce on the awning when the wind blows with the knobs tight.
Make sure to loosen when retracting awning or it will bind.
2015 F-250 FX4
Old 04-25-2016, 05:30 PM   #4
nomad297's Avatar
I forgot to mention that if you are trying to control which end the water dumps from, tighten only the one knob on the side you don't want it to dump from.
Bruce
Old 04-25-2016, 05:44 PM   #5
Better to install support poles and tie it down with ratchet straps and dirt screws and slope it to dump. Then you can leave the knobs loose all the time.
Old 04-25-2016, 05:50 PM   #6
Flybob's Avatar
I use these attached to the knob I tightened so that I don't forget to loosen the knob before I roll it up. You can find them on Ebay. I use the 6" ones.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-25-2016, 06:44 PM   #7
Smile
Thanks! I really appreciate this forum. I get fast replies from seasoned veterans!
awning
