Originally Posted by Heymirth
Does plugged into Shore power save the battery power????
That is a 2 sided question. If the battery is charged, shore power will keep it charged but if it's flat, like is stated above, takes a long time to recharge it..but.........
Anytime you discharge a flooded cell battery (or AGM) below 50% charge, the life of the battery is severely shortened because conventional batteries (AGM included) gas off below 50% charge and they also begin to deposit lead sulfate on the plates, eventually shorting them (which is why a battery dies.)
Conventional batteries should NEVER BE DISCHARGED BELOW 50% CAPACITY.
There are batteries on the market that can be discharged below 50% without harm, they can actually be discharged to nothing without harm, but unless you arr flush, you don't want to consider one. Retail is about $800 bucks for one comparable to your less than 100 buck conventional battery and if you respect the flooded cell parameters (no discharge below 50% and check the electrolyte level, your conventional battery will last a good while.
When I'm not using my camper, it stays shore powered and that includes winter time as well. I do check the electrolyte level every month in the batteries (I have more than one).
You cannot go away and forget about your camper for months on end and expect the batteries to stay charged. Even with no parasitic draws, conventional batteries will self discharge all by themselves.
