01-18-2017, 03:04 PM
New Champion Generator - 3500W Digital Hybrid
Wondering if anyone has any experience or feedback with this Champion generator. Have not seen this model previously, I might have missed it.
3500W Digital Hybrid - Champion Power Equipment
Seems very comparable to the smaller 2800/3100 generators but with more running/startup watts
Digital Hybrid Inverter technology
3500 running / 4000 startup
2.9 Gallon gas tank
17 hour run run or over 5.8 hours/gallon @25%
64dBa @ 23 ft (versus 58/59 dBa on smaller 2800/3100 units)
81 pounds (little lighter)
Wheel kit will be coming soon according to Champion
Priced at $630 at Walmart
Any experience or feedback?
2016 Rockwood Roo 233S
2013 Ford F150 SuperCrew 3.5 EcoBoost
01-18-2017, 03:12 PM
WAY TOO NOISY for campgrounds!
Champion's actual inverter generators have noise levels in the mid-50s.
MUCH quieter.
That generator would be fine for boondocking, desert camping and motor race camping.
Sent from my SM-G930T using Forest River Forums mobile app
01-18-2017, 03:17 PM
I have the older version 2800/3100 and have been very happy with it. We use ours infrequently so it spends most of it's life under a bench in my shop. That said every time without fail it has performed.
Since it is mostly stored each time after using I run it completely out of gas then put in a little of Stihl 2cycle gasoline and then run it out again and put it away. All of my equipment (yard) has gone through the same process for years w/o issue.
I will say this, if I had to do it all over again I would most likely get 2 2000w generators and pair them together when needed. Lots of times one 2k gen is more that enough.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
01-20-2017, 02:33 PM
No doubt, a 6 db difference is a bit over 3x as loud.
01-20-2017, 02:47 PM
Insert witty title here
Actually, for every 3 db increase the total noise doubles so 6db would be 4x louder.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
01-20-2017, 02:54 PM
Weird....I don't think the OP mentioned that it would be used in a CG at all.......
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
Looks like the downside is noise.
It is an 'open frame' type of construction with inverter generating capabilities. Hence the 'hybrid' designation.
Most inverter generators are fully 'enclosed' in a shroud or body housing, which helps muffle the noise and gives them a better DB rating.
I read this on their web site...
"It is an open frame portable generator that also utilizes inverter controlled output instead of using a smaller engine and being contained in an enclosed housing. So you get the power of the larger open frame machines with the output quality of an inverter."
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
01-20-2017, 02:57 PM
Doubling power behind the sound gives a 3db increase in sound. 6 db doubles the pressure, and human perception doubles volume at 10 db.
01-20-2017, 03:17 PM
My apologies it seems I ran a stop sign and commented incorrectly.
I skimmed right over the words Digital Hybrid. Mine is the 3100 Inverter Generator.
Former Owner of
01-21-2017, 01:44 PM
Canadian Member
MUCH quieter.
Champion's website says their 3100W inverter generator has a noise level of 58 dBa at 23 ft. but I agree this new hybrid one will be too loud if you have neighbors close by in a campground. At a NASCAR track, no problem.
01-21-2017, 03:10 PM
MUCH quieter.
I respectfully disagree.
One: It's an inverter (very similar on build to a Yamaha 2800I even the inverter section on the side is almost the exacct same....
Two: It has the inverter economy switch on the control panel and will run and generate power according to load
Three: I may be a bit prejudice because I own a Champion (2000 watt Inverter) but I've had no issues with mone whatsoever and it's hard to beat the Champion price, in fact, you cannot.
If I was in the market for an open frame (cradle inverter), I'd have one in a minute. I sold (on Flea-Bay ) a while ago, my Yamaha 2800 I because it was to big for my needs. Lasted about 6 hours and was gone,,,
My advice is buy it and be happy.
01-21-2017, 03:40 PM
Did you not see the noise rating of 64db?
Sent from my SM-T377T using Forest River Forums mobile app
01-21-2017, 03:59 PM
Professional Curmudgeon
2.9 Gallon gas tank
No experience, but one thought. You might want to familiarize yourself with the pros and cons of the different types of sine waves produced by various inverters.
This one might not be the best choice for your needs.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
01-21-2017, 04:11 PM
My advise, don't buy the Champion 3500w Digital Hybrid if you plan to camp beside other people. You will have some very unhappy neighbors. Rated at 64 db that genny would be screaming with a load.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
01-21-2017, 04:18 PM
Sure did and that is at WOT, not in economy mode. 64DB is about a vacuum cleaner
53 DB at 23 feet for my 2000 watt, but then again, it's totally enclosed and...
My 2800 I was 64-68 DB at 1/4 load and before I sold it, I used it plenty campinng both in parks and the woods.
If my requirements dictated more power, I'd have one in a flash. They don't however so the 2000 is fine for me.
01-21-2017, 04:40 PM
The 64 db rating is at 25% load.
01-21-2017, 05:18 PM
Debating dB ratings of generators is a waste of time and tells you nothing. There is no standard criteria for it, and the manufacturer can basically say whatever they want.
Sent from my SAMSUNG-SM-G891A using Forest River Forums mobile app
01-21-2017, 08:04 PM
Canadian Member
In the comments section on the product page somebody posted a video of load testing that hybrid generator. You can hardly hear him talking it's so loud.
Sent from my iPad using Tapatalk
01-22-2017, 04:34 AM
All I know is that I'd get really cranky really quick if this was running at the campsite next door.
01-22-2017, 05:04 AM
No doubt I bet you could hear it a mile away or more at load based on that video mentioned. He has to scream while making the video before he even loads it. The guy who posted the video says one of the pros is "noise", It gets 5 out of 5 stars for being loud I guess.
