01-12-2015, 08:38 PM
#21
Whitedog
I purchased my leds from this ebayer ( 18 SMD 5050 LED T10 BA9S Dome Festoon Car Interior Light Panel Lamp 12V Favored | eBay ) two years ago and have not had a problem with them. The only thing I had to do was put on better double sided tape to hold them inside the fixtures.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
01-13-2015, 09:57 AM
#22
Originally Posted by boondocking
I have the Champion 2000 and highly recommend it. It may not be quieter than a Honda, but it is just as quiet. They are both rated at 53 db.
Definitely NOT as quiet as a Honda!
Yes they are both rated at 53db but there is a difference.
Here's the problem the Champion is rated 53db at---23 feet---.
Honda is rated 53db at ---9 feet---.
It is very easy to start, sometimes it takes 2 pulls to start, but usually just 1 pull.
At half the price of a Honda and the same warranty, you can go wrong.
So how loud is the Champion at ---9 feet---???
C.B.
01-13-2015, 11:37 AM
#23
Not sure where you got the 9 foot information from, but you have been mis-informed.
The standard db test is done at 7 meters (22.9 ft). Both the Honda 2000 and the Champion 2000 were tested and rated at that distance.
01-13-2015, 02:24 PM
#24
Boondocking Only
When I get my Champion I will test it with an audio meter running on both eco & regular with and without loads. I will compare it to the Honda my father has. I will post results and video. Boondocking is correct on the the Dba ratings.
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
01-13-2015, 02:57 PM
#25
My information comes from Honda Generator book page 16 that shows the db reading of all their generators.
At the bottom of the page it reads as follows:
" NOISE LEVELS AT RATED LOAD, MEASURED AT 9 FEET (3METERS) FROM THE CONTROL PANEL SIDE OF THE GENERATOR.
If you want to read it for yourself go to Hondas web site and download their brochure.
IMHO somebody's blowing smoke and it ain't Honda.
C.B.
01-13-2015, 03:01 PM
#26
Boondocking Only
I will also do a 9ft test on the CHAMPION to compare. & that's not even close to what this says.
Model
Model Number: EU2000IA1
UPC: 786102003162
Manufacturer: Honda
Made in USA: No
Engine
Brand: Honda GX
Starting System: Recoil Start
HP/CC: 98.5 cc
Consumer Engine Warranty: 3 Years
Commercial Engine Warranty: 3 Years
Engine RPM: Inverter
Low Oil Alert/Shutdown: Yes
Cast Iron Sleeve: Yes
Product Specs
Voltage 120 Single-Phase
Frequency: 60 Hertz
Alternator: Inverter
Auto Voltage Regulation: Yes
Fuel Type Gasoline
Rated Amps: 13 Amps @ 120 Volts (Single Phase)
Portability Kit: Sold Separately
Tank Size: .95 Gallons
Fuel Tank Material: Plastic
Fuel Gauge: No
Decibel Rating @ 7m: Unknown db(A)
Idle Control: Yes
Hour Meter: No
Voltage Meter: No
Lifting Eye: No
Battery: Not Applicable
Decibel Rating @ 3m 59
Overview
Assembly Required: No
Weight: 46.3 Lbs. (21.00 kilograms)
Dimensions: 20.1"L x 11.4"W x 16.7"H
(51.05 x 28.96 x 42.42 cm)
Off Road Package
Boondocking Only
01-13-2015, 03:09 PM
#27
Boondocking Only
This stat sheet is a lot different.
So at 7m I'll bet it's 53
Off Road Package
Boondocking Only
01-13-2015, 03:25 PM
#28
Retired Member
Just for the sake of the thread.
Champion 2000 Specifications
Max Watts2000 WattsAC Load120VPhaseSingleFrequency60 HzEngine80cc Champion OHVOverload ProtectionAutomaticRPMAutomatic (based on load)Fuel Capacity1 gal. (3.8 L)Oil Capacity.42 qt. (.4 L)Recommended OilSAE 10W-30Start TypeRecoilLow Oil Shut-offAutomaticPortabilityBuilt-in handleChoke TypeManualNoise Level53 dBA at 23 ft.Length19.3 in. (49 cm)Width13.2 in. (33.5 cm)Height16.3 in. (41.5 cm)Weight48.1 lb. (21.8 kg) (*net)EmissionsCARB (50 State)
[FONT="Comic Sans MS"][COLOR="Blue"] Whitedog
Wife Karin and dog Shaggy
1997 Ford F250 XLT 7.3 Diesel 4X4
2001 Wildwood 26FS 5th (2015 Totaled)
2005 Cardinal 30TS 5th (2015 New beginning)
01-13-2015, 03:39 PM
#29
I have the Honda 1000 inverter which I use for my boat (lund fury) and a Yamaha 2400 which I use for our 34 ft. hemisphere. We go primitive camping often in the north woods of Wisconsin. Honda and Yamaha are top of the line, flip a coin,, it comes down to the spec's ie. weight, dimensions, gas tank, fuel shut off etc. to which one you will choose. Nothing is as quiet the Honda or Yamaha, Honda 3000isu is the lowest dba. The Champion 2000 & 3000 are the best in their range, but remember its hard to find a local dealer for repairs and parts. If your not doing 60 percent of your camping in the primitive,,, you'll be alright with Champion. PS the 2400 Yamaha will not run my 15000 btu, it did run the 13500 but I don't need a/c around Lake Superior.
01-13-2015, 04:21 PM
#30
I think you would be right.
I have compared noise levels of my Champion to my friends Honda side by side. If you did not know the specific sound of each, you would not be able to tell which one was running based on noise level.
01-13-2015, 04:40 PM
#31
I bought a Champion 4000/3500 three years ago from Camping World on sale for $319 and have had no trouble with it. Cranks on the first or second pull and runs everything I need in the TT [Aviator Wright Flyer]. May not be the quietest unit on the market but at their now price of $425, you can buy a FLEET of Champions for the price of one equal rated Honda unit. Keep the oil changed and Sea Foam in the fuel and you should have no problem. ALL companies produce a "bad unit" now and then, but don't hold that against the entire product line.
01-13-2015, 05:31 PM
#32
C.B.
I had a look at the manual, it does gives a db rating at 3 meters not 7 meters like most others do.
Every website that I have visited that are selling Honda 2000's give a rating of 53db at 7 meters. That is what I was going by.
Oh well, learned something new today.
01-13-2015, 06:32 PM
#33
C.B.
My guess is--a little louder.
I also have the Champ 3100. It had some major issues right out of the box, took some carting it around to the local Champ warranty service center and finally shipping it back to the factory, but it appears to be fixed now. Won't know how it performs until I start using it this spring.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
