Old 06-15-2014, 06:46 AM   #1
New LT tired
I finally got my new LT tires. The new tires are:
Michelin LTX M/S 2
LT275/65R18E1 123R W
What air pressure should I use for regular driving and towing?
Thanks,
Randy
Randy in Texas
TV - 2013 Ford F-250 PS Diesel
TT - 2014 Palomino Puma 28DSBS
Grif76040 is offline   Reply With Quote
Old 06-15-2014, 06:57 AM   #2
jonrjen's Avatar
I assume these are on the truck and not the trailer...correct?
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
jonrjen is offline   Reply With Quote
Old 06-15-2014, 06:59 AM   #3
Michelin LTX M/S 2
Thanks,
Randy
What LR are they, LRD or LRE?
Old 06-15-2014, 06:59 AM   #4
acadianbob's Avatar
I run 40 pounds in my LT truck tires when unloaded. It has been working great. Nice even tread wear. A little better ride.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 06-15-2014, 07:04 AM   #5
Have GY LR E on mine and run 65 rear, 60 front when loaded, 30 rear, 35 front unloaded. So far, nice even wear.
Old 06-15-2014, 07:05 AM   #6
They are LRE.
Randy in Texas
Old 06-15-2014, 07:06 AM   #7
Blackrock's Avatar
There is a place on the tire sidewall that has the recommended air pressure for that tire. It also has loading info as well.
Also check the door sticker on your truck and they should be pretty close.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 06-15-2014, 07:12 AM   #8
Herk7769's Avatar
Here is what I do with my LT245/75R/16E tires. You would need to look up the tire pressure charts for your truck tire size.
Michelin Americas Truck Tire Load & Inflation Tables
Normal driving 70 front 80 back
Towing 80 front 80 back.
Since I only use the truck infrequently (not towing) having it ready to go is more important than running it partially deflated; then having to pump it up when I want to connect.
Course, I have the diesel with Allison transmission and the empty weight front axle is 4060 pounds - 440 pounds from maxed out (4500) in any case.
http://www.tirerack.com/tires/tirete....jsp?techid=1&
http://www.tirerack.com/tires/tirete....jsp?techid=72
http://www.tirerack.com/tires/tirete...jsp?techid=147
http://www.tirerack.com/about/techcenter.jsp
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
tire
