02-04-2018, 11:57 AM
what size storage canopy?
Hello new here and to camping. have rockwood 2906ws and would like to have wooden shelter built to keep out of weather and use when home with slides out. what size would work? thinking 13'6" h x20'w x 40' l. may be overkill. Thanks
02-06-2018, 07:52 AM
Welcome to the forum its a great place to get your questions answered. You are asking a question only you can answer and be happy with the end result. What I would do is to Open the slides measure side to side and add 10' I would do the same from rear bumper to coupler.
Retired Navy
2016 Flagstaff 26 FKWS
02-06-2018, 08:07 AM
I think your "right on" as to the size your considering. It is very close to the building I built a few years ago and it nice to have the extra size for other usage or IF you decide to go with a larger RV. Go for it, your thinking correctly!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
02-06-2018, 08:23 AM
I have two "cover-tech" garages that I have had for a few years now. Really happy with them and quicker than putting up a structure.
02-06-2018, 09:13 AM
Yea we Plan on being out there a lot. Teenagers in house and all. Thanks for your advise and help. I'm getting all kinds of information here. And need it too.
02-06-2018, 02:09 PM
If you might ever consider moving up to a 5th wheel, I suggest you build it too big for now, but so that it might accommodate a potential future purchase. Same thought on electrical, if you are going to run power I would include both 30 and 50 amp.
02-06-2018, 02:12 PM
Rule of thumb: your garage should be 20% larger than your house.
02-06-2018, 02:17 PM
LOL
1930 lbs CCC
2014 Jeep Rubicon JK
02-06-2018, 04:36 PM
So true where I stay. My RV is 50 amp why suggest both 30 and 50 amp? was going to run 50 amp. Thanks for imput
02-06-2018, 06:16 PM
Make sure you understand and explain the wiring for your 50 amp if you hire an electrican. Seems all to common lately that people ask for a 50 amp connection and wind up with 240v instead of 120v and everything goes up in smoke.
02-06-2018, 06:54 PM
I am not familiar with your unit, so wasn't sure if it was 30 or 50 amp service, that is why I suggested both.
02-06-2018, 07:50 PM
Oh ok thank you.
02-06-2018, 09:30 PM
Welcome to the forum and camping. When you build your shelter you should consider having a water and sewer connection for use when home. I have water and electric but no sewer. (Keep thinking about it but haven't done it yet.)
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
02-06-2018, 09:46 PM
a 50 will run both. you use an adapter change 50 to 30.
02-06-2018, 09:58 PM
Be sure you install that by the light of the moon. ...er... no moon
02-06-2018, 10:10 PM
Not knowing your full situation, this might not apply. Do you have shelter for your tow vehicle ( garage or other structure ). If so, would that shelter work if you need to upgrade later, should you go to a 5th wheel ( 1/2 ton vs 3/4 or 1 ton ). If you don't currently have TV shelter ( or might need more space later ), you might consider going wider. I'd also go a bit taller. You're good now, but in the future, you might need a bit more vertical clearance.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
02-06-2018, 10:39 PM
Do me a favor and call me wife and tell her that!
Thanks in advance
02-06-2018, 11:38 PM
Maybe go to 24’x40’x14’ high. You can get a 5er under that.
Go with the 50 amp receptacle. Electricians won’t screw up the 50 amp receptacle, it’s 240 volts. It’s the 30 amp 120 volt receptacles that they wire for 240 volts and fry things.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
02-07-2018, 12:08 AM
Yep, I've seen it done.
02-07-2018, 09:15 AM
Thanks in advance
Ha, I could actually have my wife call her. It was my wife that got me into track days and cars.
