Old 04-17-2008, 10:00 AM   #1
New Rockwood Tt
IS IT NORMAL FOR A NEW TT TO LEAN A LITTLE?
OUR NEW 8317SS IS A LITTLE HIGHER ON THE SLIDE SIDE.
I WONDER IF IT IS INTENTIONAL TO OFFSET THE WEIGHT
OF THE SLIDE? NOT SURE?????????????
HOWIE BEDELL is offline   Reply With Quote
Old 04-17-2008, 10:26 AM   #2
I've never heard of that. but that doesn't mean anything..............
aintgotnun is offline   Reply With Quote
Old 04-17-2008, 10:35 AM   #3
Rockinwood's Avatar
I have never noticed that, are you on a level surface? How is the tire pressure? next time I am on a level surface I will check,
Jeff
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 04-17-2008, 11:12 AM   #4
I First Notices It Driving In My Mirrors,i Thought I Was Nuts
Then We Stopped At A Truck Stop And I Noticed It Again.
The Dealer Never Heard Of It.
Im Gonna Measure From The Ground To The Wheel Well.
Old 04-17-2008, 02:56 PM   #5
milzat's Avatar
Howie,
Wheel wells are not a good place to take a measurement. The sheet metal covering the flooring, from underneath, is very thin and are distorted.
Park on a known level hard surface and measure from the axle mounting spacer to the surface.
milzat is offline   Reply With Quote
Old 07-14-2008, 02:48 PM   #6
jdeeter's Avatar
Get it on a level ground and measure the frame on both sides front and back of the rig. You should have the same measurement on both sides in front and back. It is the side to side comparison to use not the front to back. You could have a warped frame. My dealer is going to measure my 2604 when I take it in next as I have the same issue. I use the rear window defroster wires to check that the trailer tires are all OK and I noticed the trailer was not level with the truck as the last trailer I had was.
Jim & Eileen
Silverado 1500 Crew Cab, 5.3 ltr, prodigy controller.
2009 Rockwood 2604.
Running mates Max & Kate Chihuahua's
Hobie Kayaks on Thule rack on truck
Retired Army EOD
jdeeter is offline   Reply With Quote
