Old 01-13-2015, 09:22 PM   #1
New sabre 36QBOK heat and air.
Ok, New camper (picked it up Saturday) and working on things that don't work the way I think they should. First is A/C air flow to vents.. Not much of it. I pulled the cover off of the main unit and found that the duct work was not connected properly from the factory. I will be patching some holes in the taping of the unit to stop air from being pulled from the attic space. I have attached some pics. I am not happy with the furnace duct work either so I will be looking at options. Has anyone made any changes to the furnace ductwork?
ID:	68402   Click image for larger version
ID:	68403   Click image for larger version
TheOrrs is offline   Reply With Quote
Old 01-13-2015, 11:01 PM   #2
Fulltime family RVer
Sadly, seems common. I asked that my ducts get looked at for the same reason- low airflow in the bunkhouse.
Old 01-14-2015, 05:56 AM   #3
Oklahoma Proud
MillerTime's Avatar
Not the furnace ducts, ours work great! On the ac vents, our 36 seems to leak air into the attic area. Found that out when i was removing one of the attic vents last summer. Our Sabre has been at the dealer since just before thanksgiving, and they are suppose to check the ac duct work to see if its all sealed or to seal it better.
Good luck!
Old 01-14-2015, 06:49 AM   #4
TURBS's Avatar
My sabre was missing the plenum for the a/c .
It also had incorrect ductwork for the main bedroom.
Old 01-14-2015, 12:04 PM   #5
dicky1243's Avatar
I thought mine was bad when p/u new had to take 3ft out of one heat tube that caused loss of flow now 2yrs later thermostat (dometic) 10 button won't work on heat unless you turn it off and then turn back on at 145 each i'm goin to sell the trl. and get another one.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 01-14-2015, 04:52 PM   #6
Exclamation Heat and Air
Seems most of us have these issues with faulty duct work (perhaps many more do not realize they have shoddy duct work) On the assembly lines the units are visible during assembly so why is it we have to quality control the products? It would be so easy on the assembly line to ensure the seams are taped and no holes are left unsealed. This type of repair is so basic, it concerns me on what issues ( safety in nature) are passed over.
The Villager is offline   Reply With Quote
Old 01-14-2015, 06:46 PM   #7
There are lots of threads here on FRF concerning RV quality control. I doubt we need to rehash it here.
Old 01-14-2015, 07:00 PM   #8
Several people have replaced the factory stats with home units the only thing they needed to do was to add a switch for the two speed fan. might be an option unless you just want a new camper.
Old 01-14-2015, 07:33 PM   #9
asquared's Avatar
Maybe this is why my living area has trouble staying cool in the summer.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-14-2015, 07:52 PM   #10
Could be also look at the front side to see if the intake is open to the attic area. if so it will pull hot humid air from the attic. Mine is open to the attic around the wiring for the unit. easy fix.
sabre
