Old 09-25-2017, 08:51 PM   #1
New used Leprechaun
Everything works great in my used 2017 Leprechaun, except the fresh water level indicator. I'm sure the tank is full, but the indicator inside the coach says it's empty. Is this something I can fix myself? I can't even find where the tank is.
TDLucas is offline   Reply With Quote
Old 09-26-2017, 07:09 AM   #2
SeaDog's Avatar
If you can't find the tank then it might be something to take to the RV repairman. Sounds like a broken or loose wire.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-26-2017, 04:03 PM   #3
Look under the bed, lift mattress should be a hinged piece of plywood lift & should see tank. That is where it is on my 2014 Leprechaun.
Mike
siam is offline   Reply With Quote
