Old 09-16-2014, 08:27 PM   #21
Newbee Generator ?
I use 2 honda 2k generators. I use both when running the 15K AC unit and only 1 when watching TV or using the microwave or charging the battery. At 50 lbs each they're easy to carry and if one needs servicing you have the other to use.
I have a regular one and a companion
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 09-16-2014, 08:43 PM   #22
Thanks again !
That's what I needed to know. I am thinking the Honda 7000 watt Generator. I am thinking this should get the job done.
Bluesman731 is offline   Reply With Quote
Old 09-16-2014, 09:04 PM   #23
Originally Posted by zippyzrx View Post
If you need 50 amps then an Onan QD 12500 diesel....but i would figure out how to run less. Heck my house doesnt pull 10kw.
Honda does make a 7KW unit that is EU quiet and gas. I suspect you could get by with it if your careful on whats on at same time. And a heck of a lot cheaper than the Onan.
Here is a Honda engine one that should get you there and at about $3k if you need 50 amp
Gillette GPE-125EH Gen-Pro® 11,000 Watt Electric Start Portable Generator w/ Honda GX Engine
You can get down to about $2500
Decibel rating of 86 DB not so good... noisy
I run 2 Honda 2000's in parallel Quiet and fuel efficient. I have 50amp service on my 5vr and use a dog bone to get it down to 30 amp. You just have to manage the power usage... no problem.
grayfox is offline   Reply With Quote
Old 09-16-2014, 10:53 PM   #24
HONDAMAN174's Avatar
Are you going to perm mount it in your TT? It's not real portable. As most of the opinions state, they go with either a smaller pair that they can parallel together or a medium one.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 09-20-2014, 06:11 AM   #25
Cableman's Avatar
I have a yamaha, granted it's the 2400ishc but it did run my 13.5 ac fine! And better then my 3k kipor! If I really need more I would have done the ef2000is combo. Go yamaha!
https://www.yamahagenerators.com/Sea...s.asp?Cat=1818
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 09-20-2014, 07:02 AM   #26
mark0224's Avatar
Champion Power Equipment 41534 7500/ 9500 Watt Heavy Duty Portable Gas Generator Electric Start with 50 Amp & RV Outlet CARB
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 09-20-2014, 07:37 AM   #27
Roll's Avatar
You said you had two AC units. Just to be clear you should be able to run a single AC with a 30A unit but be careful what else you try to run at the same time. You will not be able to run two ACs with a 30 A service.
My coach has a 50A service shore power cord, when only 30A is available I can only run one of the two AC units at a time. If I want to run the microwave, I turn the AC off.
I also have a Onan QG 5500 generator built in and though I didn't think it would do so, it will run both ACs for me on a hot day. I turn one off when I want to use the microwave though I think it might run both ACs and the microwave without an issue.
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 09-20-2014, 07:43 AM   #28
Roll's Avatar
Just out of curiosity, what does that unit weigh? I suspect it might do a fine job but would be impossible or impractical to take along on a camping trip.
I have a 17,500w portable generator for the house, (our power goes out regularly) but it weighs 400 pounds including the cart it rides on. It is a struggle to get it in position to connect to the house.
I can run the house with that much power.
Old 09-20-2014, 08:11 AM   #29
Orion's Avatar
Newbee Generator ?
I am running both AC's on 30 amp shore right now in my 832ikbs with no issue. Granted it's only getting up to about 90 right now. I believe when it gets hotter there may be more load and 30 amp might not support both running. Be aware that when first hooked up your trailer inverter can pull a pretty good load for charging the house battery for a bit. This can limit your ac usage options also I think.
I use propane for the water heater and sometimes the fridge as well to reduce load. It makes a huge difference having both units running at least for the initial cool down of the trailer.
When I bought this trailer I went thru buy mode and thought I needed some huge generator. I ended up with a yamaha 3000is inverter generator that has served us well when needed. With the genie I cannot run both AC's.
As Roll stated the microwave use needs to be considered as well when on 30 AMP.
A little rambling but there's good info in there some where....
Sent from my iPad 6 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is online now   Reply With Quote
Old 09-20-2014, 02:26 PM   #30
Roll's Avatar
Well I guess I can only comment on what my experience has been. It could be the size of the AC units or some other difference. I can run both on 50A, one on 30A and can't run either one on 20A service.
All you can do is try and see what happens. If you hear the compressor trying to start but can't seem to get going, shut the unit down before you do damage.
generator
