Old 09-14-2014, 07:34 AM   #1
Newbee Generator ?
We have a Flagstaff 832IKBS with two AC units and two Sat T.Vs. My question is weather or not someone makes a 50 amp compatible generator? Do we need a 50 amp generator ? We would like a Honda for the quality, however we don't see one with a 50 amp plug. Also, will the 30 amp generators work with our camper? My wife is in full " stuff for the camper buying mode" right now so I will need to jump on it quick ! Any and all info is welcome. Thanks.
Bluesman731 is offline   Reply With Quote
Old 09-14-2014, 08:47 AM   #2
SharkGirl's Avatar
Blues....
I don't know all the answers to your question other than Honda doesn't make a generator large enough to power an rv. I have a small honda generator and love it. Super quiet and dependable. But rumor has it honda has one in the works. I have heard people talk of champion generator. I will try to wait for a honda one. Really don't want to listen to a noisy generator if I don't have to!!
Sorry I couldn't be of more help! 😊
SharkGirl is offline   Reply With Quote
Old 09-14-2014, 08:58 AM   #3
iceblaze580's Avatar
A Honda generator like the 3000 will work to power your rig but you will limited to 30 amp there's no problem using a 50 amp to 30 amp dog bone to connect to it
iceblaze580 is offline   Reply With Quote
Old 09-14-2014, 09:00 AM   #4
SharkGirl's Avatar
Ice...
Can you run the AC with the 3000??
2013 Aviator Electra
2007 Chevy 2500HD Duramax
& a chihuahua named Daisy
Old 09-14-2014, 09:01 AM   #5
Ford Idaho's Avatar
Honda does make them big enough to run the trailer.
PowerStroke 6,800-Watt Generator Electric Start with Honda GX390 Engine-PS906811P-H at The Home Depot
A dog bone adapter will be needed to get things hooked up.
I would seriously talk to Onan and see what they could mount in the trailer.
Old 09-14-2014, 09:03 AM   #6
If you need 50 amps then an Onan QD 12500 diesel....but i would figure out how to run less. Heck my house doesnt pull 10kw.
Honda does make a 7KW unit that is EU quiet and gas. I suspect you could get by with it if your careful on whats on at same time. And a heck of a lot cheaper than the Onan.
Here is a Honda engine one that should get you there and at about $3k if you need 50 amp
Gillette GPE-125EH Gen-Pro® 11,000 Watt Electric Start Portable Generator w/ Honda GX Engine
You can get down to about $2500
zippyzrx is offline   Reply With Quote
Old 09-14-2014, 09:17 AM   #7
30 amp - 120v = 3600watts
50 amp -120/240 = 12,000 watts
The 50 amp service will have 2 - 120volt sides (6000w +6000w)
Some high end coaches will use both sides for 240volt.
Old 09-14-2014, 09:20 AM   #8
RSchleder's Avatar
It's really a simple case of adding up the "draw" of each appliance to determine what you can run with a particular size generator. After you have the numbers for all the appliances in your unit, determine what will be running at the same time, add some additional capacity for a safety factor and you should have what you need to properly size a generator. For example, a 300 watt generator will operate 1 A/C, but WILL NOT operate 2 A/C'a on your RV.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 09-14-2014, 09:49 AM   #9
Originally Posted by SharkGirl View Post
Ice...
Yes you can run the a/c with a honda 3000
Old 09-14-2014, 10:18 AM   #10
MC9
Believe me, no one is wealthy enough to power an rv with a 50amp generator unless in an emergency. A 3500 watt Champion (299.00) is quiet enough in an emergency, and your neighbors will be envious.
MC9 is offline   Reply With Quote
generator
