Old 11-02-2015, 08:27 AM   #1
Newbie - need advice on generator purchase!
I always come here to get the BEST advice from the experts - you! We purchased a Forest River travel trailer new this summer but do not yet have a generator for tailgating, etc. What size do we need to run everything, including the AC? I do know we need an inverter generator for the noise. Any help you can give? Anywhere we could get a used one to mitigate the high cost?
xtranicedeb is offline   Reply With Quote
Old 11-02-2015, 08:56 AM   #2
moodog's Avatar
This is a good subject. I to am interested in a small but mighty inverter generator.
Moodog.
moodog is offline   Reply With Quote
Old 11-02-2015, 09:09 AM   #3
Canonman's Avatar
Not having much to go on, here are some basic considerations. In order to run your A/C you'll need something that will provide about 18 amps. The microwave is the second biggest power draw using about the same power. You likely won't be able to run both at the same time unless you go with a BIG gen.
So, two schools of thought. 1, buy a 3000 watt (27 amp) inverter type gen. They are a bit heavy but you only have one unit to worry about, maintain etc. It will run the A/C charge the TT batteries and all accessories. Option 2, two smaller units that can run in parallel, usually about 2000 watts apiece. If not using the A/C or M/W you can run one and have all the comforts.
Now, the issue of brand/price. Many like the two major brands Honda or Yamaha. You'll spend more, but the idea is they will last longer with minimal maintenance. Or there are several off brand options available at significantly lower cost. My suggestion is to figure how often you'll be using the generator and make your decision. Only you know your budget and cost value assessment. As an example, Sam's Club has a nice 2k generator for $400. Wont' run the A/C so you'll need the parallel kit and second slave unit. Their 3k unit is "I think" around $700. There are many brands and options. Personally I chose a Dometic brand 3000k single unit. Works well and I can lift it in and out of the truck. IMHO please stay away from the open frame construction style generators. As you suggest they are way too noisy and a total irritant to anyone within a 1/4 mile.
Good luck and happy camping!
FR Wildwood 22 RKS
2007 1/2 Dodge 2500, Cummins 6.7
Retirement training completed
Currently enjoying second childhood
Canonman is offline   Reply With Quote
Old 11-02-2015, 09:11 AM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
Could use a little more info on size of ac and size of camper and what you want to run. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 11-02-2015, 09:21 AM   #5
Start with a Honda 3000 if you just have 1 A/C ! And you will (NOT) be able to Run Everything at the Same Time! Youroo!!
youroo is online now   Reply With Quote
Old 11-02-2015, 09:39 AM   #6
Thank you!
For the excellent advice! If anyone has anything else to say, please feel free! We have a 29' Forest River travel trailer with one AC unit and would probably only run a generator about 5 times a year for a couple of days at a time MAX! Tailgating mostly.
Old 11-02-2015, 09:59 AM   #7
Canonman's Avatar
There is a 3k watt Champion brand inverter that will do the job nicely at a reasonable price 3100 Watt Inverter Generator - Champion Generators 75531I - Portable Generators - Camping World. Best to shop around for the best price.
We use our Dometic 3000 quite a bit more than 10+ days a year, but have found that since we camp mostly in the mountains in the summer we don't use the a/C much or at all. Nice to have the option though.
FR Wildwood 22 RKS
Old 11-02-2015, 10:03 AM   #8
Retired Electronic Tech
This thread might help you:
How to set up for Generator use in a A192HW with Cool Cat 10,000 BTU/1/5hp
A Honda eu2000i will start and run a 13,500 BTU A/C on a 2016 Flagstaff Micro Lite. Not that it's recommended; but if it's only used for A/C occasionally, it will do it.
retiredtechnician is offline   Reply With Quote
Old 11-02-2015, 10:11 AM   #9
B and B's Avatar
Hello,
I searched high and low for a suitable solution. Too my way of thinking the dual Honda's, extra run tank, parallel kit was costly and messy.
I found a 4 kw (3600 watts continuous) Powerhouse that does run everything including a 15k BTU Air Conditioner, Tassimo Coffee maker other loads at the same time. We bought it after we lost power at a campground and unable to sleep due to needs fro cpap machines decided it was worth the investment.
The Powerhouse is Fuel Injected, electric remote start, 10 hrs at 3/4 load on a tank. No need to burn the carb dry or remember to turn off the gas tank petcock. Most Honda in the 3,000 watt class are only 2600 watts. That would not be enough.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-02-2015, 10:46 AM   #10
You will get varried opinions on this subject. There are numerous brands that make quiet generators.
You have 2 options (mainly), you could do a 3k genny, this would allow you to run the AC and a few other things (excluding the microwave at the same time, maybe) or you could run 2 - 2ks, you do this by getting 2-2ks and parallel them to give you 4k. This would run everything (including the micro and ac at the same time, I do this with mine). I personally like the 2-2ks because of the versatility and portability. My gennies are yamahas and they weigh 60lbs each. I only use one until I need the AC, then I parallel them.
The major drawback that most people say is the cost. A new yamaha or honda will run you around 1k (give or take on deals and how many you buy). I got my first yamaha from cabelas on sale for 850. I got the second one off of craigslist/ksl for 650. The parallel cable is anywhere from free (if you buy two gennies and get a deal, to 99 bucks). My whole set up cost me $1600. I have seen on craigslist/ksl 2 yamahas with cable for $1400-$1650.
There are other brands such as ryobi and champion but I do not have any experience with them, there are good reviews and bad reviews on the performance, to include altitude problems. I have camped with a guy for a few years that has the champion and it is 3 years old and he hasn't had a problem yet. I chose the yamaha because of the name and I haven't heard anyone complain about theirs.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
generator, newbie
