Old 09-16-2015, 12:29 PM   #1
Newbie question on slideouts
Hi all we have a Wildwood 402QBQ with 4 slide outs. I checked the winterization form but could not find an answer to my question.
When winterizing the unit what is best to leave the slide outs out or bring them in?
I've have two different answers from dealers and am quite confused
Thanks in advance
Fuzzy164
Fuzzy164 is offline   Reply With Quote
Old 09-16-2015, 12:40 PM   #2
clr
I think you will get good advice on both sides of this issue. I am of the slides in for the winter opinion. You have less surface area (roof) for the weather to work on. Also the sides gaskets are compressed when the slides are in so a much tighter weather tight type of seal when the slides are in.
clr is offline   Reply With Quote
Old 09-16-2015, 01:29 PM   #3
I do not use my TT in the winter (minus a few hunting trips) when I winterize it I put the slides in. I never leave them out unless the TT is in use (active use).
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
SuicideSaints is offline   Reply With Quote
Old 09-16-2015, 01:32 PM   #4
I have a seasonal site so mine go out in April and don't come in until October. But over the winter they are in. Don't know of any reason to leave them out.
Iwritecode is online now   Reply With Quote
Old 09-17-2015, 05:15 PM   #5
Our 5th wheel is in Wellton, Arizona all year. We leave slides out (we have 3) and finds they keep the dust out better then in, when we leave it for the summer. Should find out in a month how it was for dust this year.
We put the slides-in in the winter on our 26 footer here in Alberta, due winter snow load.
mcmilia is offline   Reply With Quote
Old 09-18-2015, 06:29 AM   #6
muddyrode's Avatar
if you have hydraulic slides you want to keep them in as the rams will draw moisture and rust or pit damaging the seals or at least smear them with a light grease or hydraulic oil to protect them
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 09-18-2015, 07:00 AM   #7
A proper built unit will SEAL with slides IN or OUT,if you have issues with Dust your seals are NOT adjusted Properly! Youroo!!
Old 09-18-2015, 09:19 AM   #8
Can't see why anyone would want to have their slides out when the rig is stored or not in use.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 09-20-2015, 09:43 PM   #9
Slides In ... they are too prone to moisture/water damage as it is to leave them out unnecessarily during periods on non use.
2009 Salem PT 403FB
2005 Ford XLT Supercrew
Cookies & Chips is offline   Reply With Quote
Old 09-23-2015, 08:34 AM   #10
Out all season - in all winter.
BigPatCal is offline   Reply With Quote
Old 09-23-2015, 08:39 AM   #11
X2. Every seasonal camper at our campground puts the slides in over the winter.
Wiscampsin is offline   Reply With Quote
newbie, slide, slide out
