Old 06-14-2016, 09:18 AM   #1
Newbie - Simple question
Hi there,
First time going a full hookup and I'm not sure about one thing and getting conflicting info out in the Google world.
When I hook up to the sewer do I wait for my tanks to be almost full before opening the valves or do I just leave them open all the time as soon as I get there?
Thanks!
Keith
kthoms is offline   Reply With Quote
Old 06-14-2016, 09:22 AM   #2
Mr. Dan's Avatar
Never leave your black tank valve open. You'll get what they call the brown mound. Dump when full.
Differing opinions on grey tank valves. Some leave them open. I keep 'em closed until I need to dump.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 06-14-2016, 09:24 AM   #3
Prime Member
Originally Posted by kthoms View Post
Hi there,
Thanks!
Keith
Leave your black tank closed until its full. You need the volume to force the flush. If you need to dump before the black is full, fill it up the rest of the way with water first.
As far as the grey goes, it's a matter of opinion. Depending on how large your grey tank is and how many people are traveling with you, the grey could fill up on you pretty fast especially after showers. Personally, I like leaving the grey open at the site but others will tell you that leaving the grey valve open will allow the sewer to vent through your drains into the camper. I just make sure that I run some water down all my drains so the traps are full of water.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 06-14-2016, 09:31 AM   #4
I keep the black water tank closed until full and then dump. I keep the grey water tank(s) closed until full, then dump as needed....but always have a full grey tank to "flush" out the hose after the black water tank dump. I use one small bottle of black water tank treatment each time, and upon departure, put 5 gallons of water into the tanks, to slosh about and keep solids in suspension.
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 06-14-2016, 09:42 AM   #5
I agree with the group, keep the black closed. Not to mention if the black valve were open and on a chance the sewer drain would come off or out of the drain hole, the mess would be everywhere but where it should be.
Kevin
2009 F150 XLT crewcab 5.4L and 3.73
2010 Flagstaff 27 BHSS
tenttotrailer is offline   Reply With Quote
Old 06-14-2016, 10:18 AM   #6
OK black shut for sure until full, grey I'll shut until half full I guess, I can see the need to use the grey after the black
Old 06-14-2016, 01:03 PM   #7
Gray Tank
The reason some people choose to keep their gray open is so they don't wind up standing in 3 inches of water when they take a shower and their tank is full. Keep an eye on your gauge and if necessary dump before taking a shower and you should be set. If you don't use your RV shower like some people then it can really take a couple of days or more to fill your gray depending on your water usage and how many people you have.
Dan
2005 Chevy Tahoe
2014 Surveyor Select SV 264
2017 - 45 Nights Camping
Beluga is offline   Reply With Quote
Old 06-14-2016, 01:05 PM   #8
beagle22b07's Avatar
Black Tank Flush
If you have one, get in the habit of using it to fill the black tank prior to dumping it. I also use the GEO method in both of my tanks. Google it and you'll see what it is. Since I've started using the GEO method, I've had no false sensor issues. Welcome to the forum.
Larry & Chris (Abbey & Brody camping cats)
2016 Ford F-150 XLT Sport, Super Cab, 3.5 EcoBoost, 3.55, 4x4, MaxTow w/36 gal fuel tank
2015 Rockwood MiniLite 2104S, EMS-30HW, Carchet TPMS
Days Camped: 2015 = 51; 2016 = 59; 2017 = 20
If you're lucky enough to be camping......You're lucky enough.
beagle22b07 is offline   Reply With Quote
Old 06-14-2016, 01:27 PM   #9
With full hook ups,I leave the gray open until the night before we leave. We both take showers and have enough to flush the hose when I dump the black. Galley tank stays closed just because it'll hold several days of dish washing.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
DaveandSue is offline   Reply With Quote
Old 06-14-2016, 01:32 PM   #10
Flybob's Avatar
Black always closed until full. Grey depends on whats going into it. If dish water with food particles then closed as well until almost full. If only liquids (no food particles) then either option it's up to you.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
newbie
