Old 03-17-2016, 07:47 AM   #11
phillips's Avatar
I'm no expert but i am pretty sure that a water softener is designed to remove calcium and magnesium ions (hard water). I don't believe a water softener will help with Iron.
current TV-2016 F-150 3.5 Ecoboost Max Tow
current TT-2016 Apex 300BHS
Reese Dual Cam WDH
phillips is offline   Reply With Quote
Old 03-17-2016, 08:31 AM   #12
Pickin' & Campin'
You will be unsatisfied with a canister type filter or just a water softener for your high iron water. I know you said you'd like to keep it inside your rig but you need to seriously think about a residential type iron filter/water softener combination system. A small storage shed at your seasonal site could house the components.
There are some small units out there but for the amount of people you mentioned will be using water (and the frequency) nothing small is going to last and continue to work for very long.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-17-2016, 11:40 AM   #13
Originally Posted by spock123 View Post
Amazon has some good prices on water softeners. I plan to buy one soon
I you have iron in your water don't buy a softener. They work great for calcium, but not iron unless it is a very very small unit.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
newbie, water
