Old 03-29-2016, 01:50 PM   #11
Mr. Dan's Avatar
Originally Posted by racen View Post
there is one on the inside but it has a kotter pin though it so it cant be turned on with out removing it, so both switches have to be on for the water heater to work on ele? an also thank you for yalls info an responcess!!
When speaking of water heater switches, the terms 'inside' and 'outside' refer to inside and outside the RV. Surely the one with the cotter pin is outside the trailer.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 03-29-2016, 01:53 PM   #12
you mean interior, or the switch in the heater itself?
racen is offline   Reply With Quote
Old 03-29-2016, 01:59 PM   #13
thanks to all but i think boondocking's explaination helps me out
Old 03-29-2016, 02:06 PM   #14
Mr. Dan's Avatar
Do you have TWO switches with cotter pins?
Old 03-29-2016, 02:37 PM   #15
nope, just the one inside the heater itself
Old 03-29-2016, 02:53 PM   #16
Ford Idaho's Avatar
One thing you need to be sure of is that the water heater is full BEFORE you flip the switch's.
Check the valves, should be located inside, likely behind a panel of some type.
On the outside of the water heater flip the pressure relief valve so water can run out of it, as soon as there is a good stream of water flip the valve closed.
Old 03-29-2016, 03:25 PM   #17
These switches confused me also. My first camper was gas only hot water heater. When I go out this year I'll have to refresh my memory of how to get thing to run on electric.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
Old 03-29-2016, 03:44 PM   #18
yea thats how my tt's were gas only, so this ele stuff is all new!
Old 03-29-2016, 04:59 PM   #19
Turn the outside switch on and you have electric heat. Turn the inside on and you have gas heat. If you use lots of hot water you could turn them both on and your hot water recovery time is much faster.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
larryo is offline   Reply With Quote
Old 03-30-2016, 10:16 AM   #20
PSUFan1's Avatar
Make sure you have water in the tank before you turn on the outside switch otherwise you will burn out the element.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
newbie
