Old 03-29-2016, 11:38 AM   #1
newbie with another question , go figure lol
hot water heater switch, the switch to the left is this for the hot water heater, or the furnance
racen is offline   Reply With Quote
Old 03-29-2016, 11:42 AM   #2
I would assume water heater, as the furnace should be on a thermostat.
Mikele is offline   Reply With Quote
Old 03-29-2016, 11:55 AM   #3
Ford Idaho's Avatar
Yes the bottom one is for the water heater.
Depending on what brand it is there may be one on the water heater outside.
Old 03-29-2016, 12:54 PM   #4
Suburban water heater , the switch is to run your water heater on electric instead of propane
VetteJohn is offline   Reply With Quote
Old 03-29-2016, 12:56 PM   #5
there is one on the inside but it has a kotter pin though it so it cant be turned on with out removing it, so both switches have to be on for the water heater to work on ele? an also thank you for yalls info an responcess!!
Old 03-29-2016, 01:11 PM   #6
To run on electric turn on the switch with the cotter pin. Be sure to turn off cotter pin switch when finished camping. To run on gas only, leave cotter pin switch off and turn on the switch inside the trailer that says HTR. Both switches do not need to be on to run on electric.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-29-2016, 01:15 PM   #7
turn this, switch that, hit these, an run!!! lmao what did i get into??
Old 03-29-2016, 01:29 PM   #8
It's not as bad as you think.
2007 Surveyor SV230
Old 03-29-2016, 01:29 PM   #9
Ford Idaho's Avatar
A more or less normal used Travel trailer.
Old 03-29-2016, 01:32 PM   #10
PSUFan1's Avatar
We turn on the internal switch (gas) when we know we are going to use a lot of hot water (showers) and then turn off when we are done.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
newbie
