03-29-2016, 11:38 AM
newbie with another question , go figure lol
hot water heater switch, the switch to the left is this for the hot water heater, or the furnance
03-29-2016, 11:42 AM
I would assume water heater, as the furnace should be on a thermostat.
03-29-2016, 11:55 AM
Yes the bottom one is for the water heater.
Depending on what brand it is there may be one on the water heater outside.
03-29-2016, 12:54 PM
Suburban water heater , the switch is to run your water heater on electric instead of propane
03-29-2016, 12:56 PM
there is one on the inside but it has a kotter pin though it so it cant be turned on with out removing it, so both switches have to be on for the water heater to work on ele? an also thank you for yalls info an responcess!!
03-29-2016, 01:11 PM
To run on electric turn on the switch with the cotter pin. Be sure to turn off cotter pin switch when finished camping. To run on gas only, leave cotter pin switch off and turn on the switch inside the trailer that says HTR. Both switches do not need to be on to run on electric.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
03-29-2016, 01:15 PM
turn this, switch that, hit these, an run!!! lmao what did i get into??
03-29-2016, 01:29 PM
It's not as bad as you think.
A more or less normal used Travel trailer.
03-29-2016, 01:32 PM
We turn on the internal switch (gas) when we know we are going to use a lot of hot water (showers) and then turn off when we are done.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (20), Alyssa (15), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
03-29-2016, 01:50 PM
When speaking of water heater switches, the terms 'inside' and 'outside' refer to inside and outside the RV. Surely the one with the cotter pin is outside the trailer.
03-29-2016, 01:53 PM
you mean interior, or the switch in the heater itself?
03-29-2016, 01:59 PM
thanks to all but i think boondocking's explaination helps me out
03-29-2016, 02:06 PM
Do you have TWO switches with cotter pins?
03-29-2016, 02:37 PM
nope, just the one inside the heater itself
03-29-2016, 02:53 PM
One thing you need to be sure of is that the water heater is full BEFORE you flip the switch's.
Check the valves, should be located inside, likely behind a panel of some type.
On the outside of the water heater flip the pressure relief valve so water can run out of it, as soon as there is a good stream of water flip the valve closed.
03-29-2016, 03:25 PM
Frog-Toberfest Organizer
These switches confused me also. My first camper was gas only hot water heater. When I go out this year I'll have to refresh my memory of how to get thing to run on electric.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
03-29-2016, 03:44 PM
yea thats how my tt's were gas only, so this ele stuff is all new!
03-29-2016, 04:59 PM
Turn the outside switch on and you have electric heat. Turn the inside on and you have gas heat. If you use lots of hot water you could turn them both on and your hot water recovery time is much faster.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
03-30-2016, 10:16 AM
Make sure you have water in the tank before you turn on the outside switch otherwise you will burn out the element.
