Old 03-19-2014, 08:46 PM   #1
Newbie with questions
Recently purchased 2007 5er rockwood 8285 haven't taken on trip yet. Parked at my house to do personnel touches. Husband replacing carpet. We have had our one slide out many times and it was in and when I pushed switch nothing happened..not even sound. Checked circuit breaker..ok, fuses..ok, any other helpful suggestions will be appreciated.
beachhrlygrl is offline   Reply With Quote
Old 03-19-2014, 08:54 PM   #2
VinceU's Avatar
Are you checking CB's and fuses for circuit path with meter tester or just visible check? Slides are normally power fed direct from battery with inline fuse or CB.
Old 03-19-2014, 08:56 PM   #3
No, visible check. I went and left it plugged in..maybe after tonight battery will be stronger?
Old 03-19-2014, 09:32 PM   #4
VinceU's Avatar
Yes, maybe- if it doesn't work then search for a small black box maybe 1"x 1" x2" length with battery cables attached each end if tripped it will have a button extended or perhaps a lever sticking out of it. This "resetable fuse" will be located close to the battery, often bolted on a frame rail or stiffener. Let us know.
Old 03-19-2014, 09:52 PM   #5
Thanks..will see tomorrow and let you know. Appreciate your help!
Old 03-20-2014, 06:57 PM   #6
davel1971's Avatar
Originally Posted by markb5900 View Post
Put water in it, turn your pump on and let it run till it shuts off, then turn the switch off. Wait about 5 minutes then turn the pump back on. It SHOULDN'T come back on, if it does, then you have leak somewhere.
About the only advice I can give to check on a used trailer.
yes, but were fixing an electrical problem here.
David & Lynn
Old 03-20-2014, 07:19 PM   #7
VinceU..thanks for your help...fuse by battery bad..replaced and works great! Appreciate your assistance
newbie
