Old 09-06-2016, 08:56 PM   #1
danielabram71's Avatar
Nitrogen filled tires
My tires came from the factory nitrogen filled. My question is if they are low on air and need air added. Do you just put add air from a gas station or do you have to find a place where you can get nitrogen put in them. Does it matter or is there something else you have to do?
1014 1500 GMC
2015 solaire 267bhsk
danielabram71 is offline   Reply With Quote
Old 09-06-2016, 09:04 PM   #2
Mr. Dan's Avatar
Please do a search for Nitrogen in the search box at the top. This topic has been beat to smithereens multiple times and discussion of same almost always turns into a spitting contest. It's as hot a topic as Diesel vs. Gas, Ford vs. Chevy, propane refrigerator On vs. Off during travel. Each of 319 opinions have been expressed and in almost every thread on same, one can find someone posting "I'll get the popcorn."
SEARCH is your/our friend.
Just sayin'.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 14; booked = 28
Old 09-06-2016, 09:07 PM   #3
dieselguy's Avatar
There are many passionate threads on about any RV forum about nitrogen filled tires. My personal opinion is unless your application is an airplane ... nitrogen in your tires is pretty much an expensive sales pitch that just doesn't live up to the hype. The air you breath is already 78% nitrogen. Nitrogen fill stations are pricey, and few and far in-between. Unless the tire store evacuated the air from the tire before they filled it ... it has some regular air in it anyways. Spend you hard earned money on something that matters.
dieselguy is offline   Reply With Quote
Old 09-06-2016, 09:10 PM   #4
NMWildcat's Avatar
Yep, Google the subject and you will find all kinds of claims, but in the end testing found there was minimal benefit and much higher cost. Our RV came with nitrogen filled tires and my opinion is that it is a gimmick. And good luck finding a place that has nitrogen. In the southwest they are almost impossible to find. Snake oil😁
Fill them with air and don't worry about it.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-06-2016, 10:23 PM   #5
X2
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 09-06-2016, 10:31 PM   #6
B47
Originally Posted by Mr. Dan View Post
Please do a search for Nitrogen in the search box at the top. This topic has been beat to smithereens multiple times and discussion of same almost always turns into a spitting contest. It's as hot a topic as Diesel vs. Gas, Ford vs. Chevy, propane refrigerator On vs. Off during travel. Each of 319 opinions have been expressed and in almost every thread on same one can find someone posting "I'll get the popcorn."
Just sayin'.
Mr.Dan is right on here. There is no right or wrong answer or choice.
Old 09-06-2016, 10:39 PM   #7
I just took the sticker off the side of my new trailer. Nobody I know cares if it has nitrogen in the tires and I certainly don't either. If it really has nitrogen, (how would you know?) it will be the last time.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 09-07-2016, 04:55 AM   #8
Ok sorry to start a war. When my nitrogen Field tires get low. I will just go to a gas station and refill them with regular air. Thank you
1014 1500 GMC
Old 09-07-2016, 05:22 AM   #9
Oaklevel's Avatar
Even the tire and car dealers will off the record admit that for passenger cars and trailers it is just a sales gimmick. Different story for aircraft and racing tires.
I have personally seen no benefit, but pass the popcorn I will catch it
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 09-07-2016, 05:22 AM   #10
waiter21's Avatar
Whenever I fill my tires, I always use an 80% nitrogen mix, Its been working for me for years.
NOTE - the air you breath is 80% nitrogen, the compressor at the gas station will do just fine, it also is 80%.
Why I use 1100% nitrogen in my airplane tires:
1) We use a high pressure nitrogen bottle (3000 psi) when we service our tires to as much as 250 psi. Most standard compressors will not get to the pressure we need in our tires, and are horribly inconvenient to haul around to check and add air to tires.
2) Gas station compressors don't dry the air. The nitrogen in the tank is waterless, and has been dried, thus eliminating the possibility of water condensing and freezing inside the tire. Unless you drive your car at 40,000 ft with an outside air temperature of -65 degrees, this will probably not be an issue.
3) Autoignition - When a 250 psi tire reaches a temperature of approximately 500 Deg F, There is a possibility of the tire exploding if it has an oxygen source internal (not filled with 100% Nitrogen). The FAA has tested this and has issued an directive to use 100% nitrogen.
http://rgl.faa.gov/Regulatory_and_Gu...d!OpenDocument
4) At the high pressure, nitrogen is molecularity larger than an oxygen molecule, and can reduce minor losses of tire pressure and minor degradation of tire rubber due to oxygen impregnating the rubbers used in tires. (very minor issue, but is more of an impact with high pressure tires (450 psi)
Its important to note that item #4 isn't the reason Nitrogen is used in airplane tires, but is a small side effect of using nitrogen in aircraft tires.
The main reason is items #1 and to a lesser degree, #2. #3 is somewhat irrelevant, as at 500 Deg, the tire is on fire.
I suspect if I took two aircraft tires inflated to 250 psi, one was inflated with shop air and the other out of a nitrogen tank. You could set them on the ramp for ten years, and when you come back, you'd see the one with shop air lost a couple psi more than the one with 100 % nitrogen.
CONCLUSION - Would I use nitrogen in my car tires? No, the extremely small benefits for car tires isn't worth the addition work or cost.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
led, tire, tires
