Old 05-15-2016, 01:02 AM   #1
NO DC Power in 2011 Rockwood Mini Lite 2306
Hi There, We recently upgraded from our PUP and bought a 2011 Rockwood Mini Lite. We are getting ready for the first trip next weekend and we tried to run it off DC power as we will not have services at the park.
So we disconnected from shore power and cannot run anything off the battery, not even lights. I thought the Previous Owner disconnected from shore power when we were looking at the trailer and the lights worked...I am now second guessing myself.
Also, when disconnected from shore power, the fridge was not working (but worked well when connected to shore power).
I have searched through many forums, and I am hearing of people having switches that may need to be reset.
Anyone out there with the same Travel trailer that can help??
Thanks in advance!
The Rockers is offline   Reply With Quote
Old 05-15-2016, 01:40 AM   #2
Check for a disconnect switch close to the battery that is not turned on. Look for circuit breaker connected to the battery cable not very far away from the battery terminal, usually the positive cable. It may be a re-settable breaker or an auto reset that has failed.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 05-15-2016, 05:11 AM   #3
RSchleder's Avatar
X2 on 12V on/off switch. Typically mounted on the inside of the trailer tongue close to the battery. I have, however, seen them mounted elsewhere, both inside and outside the unit.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-15-2016, 05:56 AM   #4
crunchman12001's Avatar
Is the battery good and fully charged?
2015 F-250 FX4
Old 05-15-2016, 06:26 AM   #5
Thanks, we did have a quick look, but will take a more thorough look in the morning.
Old 05-15-2016, 06:34 AM   #6
I don't think the 2011 had a disconnect. I don't think they added it until 2013 but I may be wrong. My disconnect is under the tongue on the cross piece between the propane tanks and the jack. It is a red key that turns. Some did have a disconnect at the converter that you pull out. Other things to check:
Is the battery actually hooked up
There are to big fuses in the converter, I think 40 amp, are they good
Do you have a meter to test battery voltage
Is your converter putting out any voltage to the battery
These are a few thing to run through first
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 05-15-2016, 09:31 AM   #7
KDHfan's Avatar
Ours was a 2014 I think, but the disconnect switch was located inside below the fridge.
There must be a disconnect switch somewhere. I would contact the previous owner and see if he installed one himself. Or, ask him what's up.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 05-15-2016, 09:52 AM   #8
Flybob's Avatar
Since this is a 2011 it is likely that you have the original battery which at best will be marginal for non hookups. If you brought it home after purchasing and seeing that lights etc worked, and it has been sitting without being connected to shore power, most likely the battery has been depleted. The CO/Propane detector in most trailers is always on and over a month or so will drain the battery ( especially if it is an older battery). If you are counting on battery power for your trip. I would remove the battery and take it to an auto parts /battery dealer to have it load tested. It may appear to charge with a charger, but may not support a load for any period of time. The fridge control board needs a min voltage from the 12V system to operate even if operating the fridge on propane. Below that min, the system will shut down as a safety feature.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-15-2016, 09:59 AM   #9
First things first.... I would bet the battery is dead. Let's eliminate the obvious before we get to crazy.
2015 F-250 FX4
Old 05-15-2016, 02:13 PM   #10
mkillora's Avatar
On my 2012, 2109s, the battery disconnect is located below the fridge beside the electric panel/converter. May be similar to yours(?).
mkillora is offline   Reply With Quote
2011, 2306, power, rockwood, rockwood mini lite
