I was wondering if you could clarify.
You have a Global Link G3xx keyed door on your RV. Then you bought cam locks from RVLocksandmore.com that were keyed to G3xx. But, you couldn't use the provided keys to operate both your cam locks and your RV door locks?
Isn't that the entire point of this ... to key the cam locks for the storage covers to the same as your door?
Otherwise, how do you even keep the keys straight? They'd both look identical and both be marked with the G3xx code. You'd have to compare the teeth to know which to use in which lock?
I'm fairly confused by this.
Thanks.
Former RV: 2018 Rockwood Mini Lite 2504S
