Old 05-25-2015, 02:43 PM   #1
non electric site
newbie here, wondering how it works at a non electric site. if i can run a generator for few hrs what can and can i not run in my trailer, and what is the exact purpose if running the generator? what do u do about the food in refeigerator and can i run my hot water heater off gas?
Jfmf527 is offline   Reply With Quote
Old 05-25-2015, 03:06 PM   #2
BamaBob's Avatar
Need to know a bit more about your rig before I can comment on the Refer & HWH (Hot Water Heater) for sure but, as a general rule of thumb, the refer and HWH both run off of gas as well as electric.
As for the generator, that will be a park "rule" that will change from park to park - so call the camp host ahead of time and see what their policy is on generators.
Hope this helps.
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-25-2015, 03:09 PM   #3
bikendan's Avatar
Most campgrounds have specific generator hours, usually a couple hours in the morning and a few in the late afternoon.
Running the generator is like being plugged into shore power, you can run your 110v AC items and recharge your battery and run the 12v DC things still.
You should still run the fridge and WH on propane since your generator time is limited.
By the way, didn't your dealer go over any of this with you?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-25-2015, 03:17 PM   #4
Simply put, you can run the fridge off the propane and 12 volts. You can run the water pump off of 12 volts. You can run the furnace off of propane and 12 volts. You can run your lights off of 12 volts. I have 2 group 31 batteries, some solar to keep up with parasitic draw from the fridge, gas detector. I also have 2 twin honda 2000 gennies. If you're frugal with what you run off the batteries , they could last a couple of days or more. The genny will charge your batteries and allow you to use 120 volts appliances, depending on how many watts the genny will supply and how long you run it. You don't want to deplete your batteries under 50% because the life of the batteries lessens. In some campgrounds there is a time allotted to running the genny. it's up to you to find out what that is. I'm sure others will chime in with their experiences as well.
Pipeman is online now   Reply With Quote
Old 05-25-2015, 03:42 PM   #5
i have a dometic fridge and a suburban hot water heater which i know both run on electric n gas. im just asking cause we have only went out 3 times so far to full hook up sites. so wasnt sure how things worked in a water only site.
Old 05-25-2015, 03:44 PM   #6
so if i understand correct i cannot use my outlets and a/c correct??
Old 05-25-2015, 03:53 PM   #7
strat56's Avatar
We went dry camping for the first time a couple weekends ago. I have a 2000 watt Honda generator. The park allowed generators from 8AM to 10PM I believe but I never started it before noon.
We used the generator to charge the battery and run the Television during the day. We ran the HWH and the fridge on propane. Everything else was on 12v when the generator was off. Did not use the microwave or the AC, generator was too small for them. We connected our generator to the TT using the 50 amp cable and an adapter on the end at the generator.
We made sure the battery was fully charged by the start of quiet time at 10PM because my wife uses a CPAP for sleeping and it ran on the 12V system at night. Over all it was a pleasant weekend, the temps didn't get too high and we didn't need the AC or the furnace.
Your outlets will work when the generator is connected and running but be careful not to overload the generator with anything you plug in.
What wattage in you generator? That determines if you can use your AC or not with the generator on.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is online now   Reply With Quote
Old 05-25-2015, 05:18 PM   #8
bikendan's Avatar
Outlets only on generator and a/c only on generator IF it is 3000w or more.
It would really help if you posted model of RV and model/brand of generator.
Old 05-25-2015, 05:54 PM   #9
2004 forest river salem le and honda 2000 genny
Old 05-25-2015, 06:21 PM   #10
bikendan's Avatar
Well, you can't run the a/c with that generator, but you can run the microwave, the outlets and recharge the battery with it.
electric
