Old 08-04-2015, 01:15 PM   #21
That happened to us and it took out the black water tank!! Hot pavement, 55 mph. Good Sam covered the tow. Glad u r OK.
Maggiewaggie is offline   Reply With Quote
Old 08-04-2015, 01:49 PM   #22
Just curious, we just purchased a 2016 2109s mini lite that has nitrogen filled tires. Is this suppose to help prevent blowouts?
macalr is offline   Reply With Quote
Old 08-04-2015, 02:03 PM   #23
jackdn0610's Avatar
We were just starting a 3 month trip to the east coast this past Sunday and had gotten as far as Winnemucca, NV, when our first tire blew and damaged the passenger side of the fifth wheel. After putting on the spare we decided to return home for repairs. Had gone about 120 miles towards home when the second tire on the same side blew. We, too, had to wait over four hours in the heat of the Nevada desert for a replacement tire. We didn't have quite as much damage as "dnwiginton", but it was bad enough.
Taking the rig in this Friday for repairs to begin and will definitely replace all of the tires with LT tires (probably Goodyear G614's)
ID:	84910   Click image for larger version
ID:	84911   Click image for larger version
Jack & Jo Neihouse
Grass Valley, CA
2014 Cardinal 3450RL
2011 Ford F350 SD DRW
F.R.O.G. Members
jackdn0610 is offline   Reply With Quote
Old 08-04-2015, 02:20 PM   #24
Geojudi59's Avatar
Marathons
When we first bought our rig it came with Chinese Marathons. We were heading
east on the interstate I 10 in texas I heard the pop as one tire exploded.Not to much rv damage . drove home to NY at 50 mph after that. Got rid of the china bombs
Running Good year 614 G rated now.
George & Judy... Our Quincy is gone but Never forgotten.
we now Have a Golden Doodle pup
2010 Brookstone. 2400 Watts of solar 1500w inverter,4 T105's
Geojudi59 is offline   Reply With Quote
Old 08-04-2015, 02:34 PM   #25
AquaMan's Avatar
Originally Posted by ndwiginton View Post
I weighed as soon as I pulled back into town. 2011 3500HD crew cab with 365SAQ. Total - 22800. Trailer - 11480. Wasn't running any type of TPMS at the time but plan on it from now on. Thinking of going with the Michelin XPS Rib but will be real close on weight is my concern.
I'm guessing that trailer weight is actually the axle weight on the trailer, and not the total weight. Dry weight on a bone stock 2012 365saq is 11,800. I don't remember from the pictures, but were both blowouts on the same axle? You may want to check for a bent axle or springs.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 08-04-2015, 02:50 PM   #26
You said the magic word, Marathon. Replaced a set of 4 two year olds under my Montana when I discovered both wear and bubbles. Replaced them with Michelin XPS Rib. That was about 4 years and 40,000 miles ago. Michelins are doing fine. No significant wear and certainly no bubbles. They cost, but I've never been left beside the road on Michelins.
For what it is worth, in a former life, had a 1998 Cardinal with 3 axles. Had heard about such problems, so carried 2 spares. Blew 3 tires between Jackson MS and Tampa FL. I, fortunately, could limp in on 5 tires and one rim. Replaced all 6. Think they were Generals, but not sure.
I think, regardless of the brand used by the RV manufacturer, they are buying the cheapest available tires and the tire manufacturer is shipping the old stock they couldn't sell.
RubberNail is offline   Reply With Quote
Old 08-04-2015, 02:58 PM   #27
Marathons used to be made in the US then they sent production to China then brought it back for a year or so then sent it back to China so it is possible that you got China Bombs on your 5th wheel.......I put G614's on our 5th wheel prior to taking a trip to Alaska last Summer. They did not even loose air. I was anticipating having blowouts on the Alaska Hwy so I bought and extra spare and another spare tire carrier for the rv. Did not have a problem with 5th wheel but one day while visiting Medora ND we had a flat on the truck while shopping in town....The truck had LT tires so just having LT tires will not prevent a flat....
Bob Vaughn is offline   Reply With Quote
Old 08-04-2015, 04:09 PM   #28
Any of you try these Flat Stoppers?
I am thinking of trying these Flat Stoppers to park the trailer on when it is home. They aren't cheap, but maybe they will help with the flat spotting/belt separation that seems to be plaguing us. My Salem is in the shop now for wheel well repair, my brother just ripped off the side of his trailer when he had 2 blowouts at the same time.
Flatstoppers.com, Vehicle Storage Car Ramps
I Roo The Day is offline   Reply With Quote
Old 08-04-2015, 04:14 PM   #29
Mrs Evans's Avatar
Interesting product, never heard of these before
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 08-04-2015, 04:27 PM   #30
wpgman19's Avatar
So after reading all these forums about blowouts and the damage they do to the slides and shell, why don't the manufacturers build something around the tires/wheelwell areas that will restrict the damage to the blown tires alone? Seems like common sense to me - oh wait, maybe that is my answer!!
2014 Rockwood 8310SS Diamond
2014 F-150 Super Cab Ecoboost w/Max Tow
Nights Glamped - 2015 - 24
Nights Glamped - 2016 - 4
wpgman19 is offline   Reply With Quote
