Old 07-27-2013, 09:32 PM   #1
Gregg Willow's Avatar
Not another generator thread...
As my title says, it's another genny question. I have read just about every thread concerning this topic but I want to give it one more toss at the masses before I drop $2000+.
I am purchasing the EU3000is or two EU2000is's next week. I need your help in my decision.
The 3000 is just sweet. Heavy sweet. It purr's like a kitten on Eco at 48db and I have witnessed this. But under a/c load it should run at 58db where the 2000's will run at 59db under the same circumstance. It is the 1/4 load that the 3000 shines in my frame of mind. Again, heavy. I can use my ramps into the truck bed though.
Okay, now the 2000. Light weight, a minimum of 53db @ 1/4, can dual to 4000 watts, are susceptible for easy theft, 15,000 a/c capability?, etc. Lots to think about.
For around $2400 I can get a 3000 with the wheel kit and remote start. The same money I can get the 2000's with the parallel cables and the BERGS dual feed extended run 6 gallon tank that can run for 36 hors on the two.
I have a Champion 3500/4000 from the advice from some else. It was okay at a big concert but not to be used at a CG. Has to be replaced. I am now 50 and 6'2" and still able to put 160lbs of the 3000 full of gas in the truck bed (kind of, but for how long?)
I guess my main thought is, as a next door camping neighbor, would two 2000's or a 3000 be preferable or does it matter? I'm hinting at the 2000's. On cool days there is no reason two run two 2000's and like the idea of just taking one with me. Than again, I'm not sure a 3000 could handle a 15,000 a/c that i"m thinking about in the future. Only want to buy this one time.
Thanks for any of your replies.
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 07-27-2013, 10:27 PM   #2
If your worried about your neighbor, don't buy one, especially if they are in a tent. As far as one vs. two, I would think one would be less obnoxious, as two, out of sync, would tend to create a wobble sound (I can't think of the right term for the sound two engines make when not synchronized)....
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 07-28-2013, 09:31 AM   #3
2011 Forest River Stealth
rwtdct's Avatar
I dry camp 99.9 percent of the time.
I have a Toy Hauler with a built in Onan 4000 . And I also have a EU3000is with a remote start I keep in the bed of my truck, when camping. The 3000 is the one we normally use (quieter and no vibration in the trailer) running almost everything. You might have a problem running air and microwave at the same time. The Onan 4000 no issues. So far as the two 2000's, you can use just one most of the time. The air con. is when you will need two 2000's
The Eu3000is is heavy and you can add a remote start.
The 2000's are light you can use one most of the time. I don't believe you can add a remote start using two of them.
Good luck with your decision.
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 07-28-2013, 09:42 AM   #4
KyDan's Avatar
I like the option of just using one smaller genny when that's enough to
do the job.
KyDan is online now   Reply With Quote
Old 07-28-2013, 09:55 AM   #5
acadianbob's Avatar
do the job.
Agree. Two 2,000's is better than one 3,000 IMO. More capacity. Ability to use just one much of the time. Lighter to heft around.
I experimented with two 2,000's earlier this year. They ran the air OR the microwave handily. They didn't really like air AND microwave; they struggled and seemed to be at their limit. From what I saw, I doubt that one 3,000 would handle BOTH.
One 2,000 would not run my air even after past the start-up. I got the air going and then shut down one of the 2,000's. The remaining 2,000 went on overload and shut itself down. That's why I don't think one 3,000 would handle both air and micro.
The 3,000's are really nice and very quiet. But there is no way that I could get one into the bed of my pickup by myself.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-28-2013, 10:00 AM   #6
Oakman's Avatar
My 2 cents. Go with the two Hondas, they should provide more useable amps. I too like your idea of running just one when the A/C isn't needed.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-28-2013, 11:14 AM   #7
Two 2000's it is. Thanks for your replies.
Old 08-09-2013, 08:57 AM   #8
IHDRIDER00's Avatar
RWTDCT, This might not be the place, But.... I want to ask you about your Onan. I have a 04 All American Sport 5th Wheel Toy Hauler. Which is set up for a generator. I also have a 4000 watt Onan Gen. Which I would like to install in the RV. Where is yours located, how does it sit in the RV? I know it might be asking a lot, can you post a pic? Thanks
IHDRIDER00 is offline   Reply With Quote
Old 08-09-2013, 09:25 AM   #9
lswartz's Avatar
That is a good choice. I got the Yamaha EF2400iSHC & it seems to be getting heavier every time I put in the the truck . Honda & Yamaha both have nice 2000's just pick the color you like.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is online now   Reply With Quote
Old 08-09-2013, 09:47 AM   #10
Actually, I just picked up the Honda's yesterday. I ran them a little bit yesterday but am camping starting today so they should get a bit of a work out this weekend. These are really nice units and I can carry one under each arm. Thanks for everyone's replies, I think this was the right choice. Going to work on getting the extended fuel tank and the handle security guards.
generator
