Old 09-15-2019, 09:14 PM   #1
Not picking up any channels
I am not picking up any channels. I have a digital antenna that doesn't raise the booster is on and I am parked in my driveway. Have performed a channel scan many times. TV is set to receiver/antenna. I have a 2018 Cherokee by Forest River. TV is insignia. I did get TV at the lake last month when a buddy set it up but I'm not having any luck now.
Montyturley28 is offline   Reply With Quote
Old 09-16-2019, 08:25 AM   #2
kfd82's Avatar
Have you ever received channels at home? Maybe you are outside of a TV area.
Where I live I can only get 2 channels over the air.
kfd82 is offline   Reply With Quote
Old 09-16-2019, 08:49 AM   #3
PPST Wannabe
kenandterry's Avatar
Maybe you can try scan again at the lake. Then youíd be comparing apples to apples. It might prove that some connection has broken.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-16-2019, 04:42 PM   #4
I have received channels at the lake about 20 miles away but have never tried in town. A buddy thought maybe my house was blocking signal
Old 09-16-2019, 05:15 PM   #5
Flybob's Avatar
At the end of the channel scan, how many channels did it find. 20miles additional is a significant distance for UHF. Get the app DTV Antennas for your phone. It will show you the distance and direction of any signals close to you.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-16-2019, 05:28 PM   #6
Zero channels after a scan.
Old 09-16-2019, 05:50 PM   #7
Do you have one of these antennas?
If so, I received zero channels with it. I installed a Winegard and got a bunch of channels.
https://www.amazon.com/gp/product/B0...Y5GO0W7S&psc=1
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 09-17-2019, 05:58 PM   #8
I had an intermittent problem with reception on my tv. I found the coax connectors loose at the antenna and at the tv. I also found the radio antenna loose at the rear of the radio. Tightening those connectors has somewhat improved tv reception but am/fm radio is just plain poor. But then we donít go camping to watch tv or listen to the radio anyway.
2015 Flagstaff 21DS is offline   Reply With Quote
Old 09-17-2019, 06:17 PM   #9
Freetyme's Avatar
You can try pointing the antenna in another direction and scan again. There are phone apps that can guide you in tower directions and how many miles away. I'm in a valley parked between 2 garages while home, can't get a thing. Couldn't with the crank up batwing either.
Freetyme is offline   Reply With Quote
Old 09-23-2019, 02:07 PM   #10
If your antenae is attached to the tv with coax tv should be set to air/cable. Make sure the booster is on before you do a scan and your antenae is up all the way. You can also turn your antenae by pulling down on the big round ring where the crank is and turn it. Make sure the little arrows line up before you lower it again though.
Then do a scan.
AceCombat is offline   Reply With Quote
Old 09-23-2019, 03:02 PM   #11
bikendan's Avatar
Then do a scan.
Actually, if using the antenna for OTA signal, you set the tv for Air, Not Cable. Then turn on the antenna booster button.
Get a tv signal app and you can find where the tv signals are being broadcast from and rotate the antenna to that direction.
Equalizer WDH
