03-01-2016, 08:56 AM
Novice Camper Question
Hello everyone,
My wife and I recently purchased a A122s A-frame popup and we love it. However we have had some issues with the camper and I cannot seem to figure them out. If anyone can answers these questions I would appreciate it.
1. We tried using the furnace and although it was working, the a/c unit ran the entire time and canceled out the heat we were looking for. Is it possible to run just the furnace?
2. Is it possible to run the furnace without power? We have been asked to go primitive camping, w/o power, and I would like to figure this out before we go, as we have a two year-old. I would appreciate any help.
Thank you,
Thomas V Klusman
03-01-2016, 09:01 AM
Originally Posted by ThomasVKlusman
Hello everyone,
Thank you,
Thomas V Klusman
Howdy Thomas and welcome aboard.
1. Does your A-frame have a digital thermostat? If so, sometimes the answer can be as simple as the fan auto setting.
2. Yes, the furnace run's off of 12 volt DC (battery) and propane. You can use it without 120 volt AC power, but it is a good energy hog. You will need a way to recharge your battery(s) if you use it much.
Although I don't have personal experience with these type heaters, I have read where several members love them and use them in place of their furnace when boondocking.
http://www.amazon.com/Mr-Heater-F232...73441043b44366
For those just beginning, I always recommend a couple of great articles by Mark Polk about what most all RV's have in common as far as understanding the electrical systems.
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
2011 Flagstaff 831 RLBSS
03-01-2016, 10:03 AM
The fan setting was likely on either hi or low. You need it on auto otherwise the fan in the A/C unit will run when the heat is on.
03-01-2016, 10:04 AM
Set your digital thermostat to Fan, and you will see 3 options: auto, lo and hi. If set to lo or hi, the fan will come on with the furnace. If set to auto, it will not. Just set it to auto. I don't think your A/C came on with the furnace, just the fan came on.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
03-01-2016, 11:03 AM
Every Fall with out fail DW and I will be camping and I forget to set my thermostat to auto and the heater doesn't go on during the overnight. Makes for good cuddling though!
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
03-01-2016, 12:07 PM
Welcome and congrats on the A122s A-frame popup!
Already great advise here for you to try out, already, so I won't pollute the water with more!
Let us know how it goes
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
03-02-2016, 07:36 AM
Thank you everybody! I will give all of this a try this weekend and let you know how it goes.
03-02-2016, 07:59 PM
Novice Camper Help
Hello Everyone,
I wanted to show you that I do not have an "auto" function. My choices are Fan, Cool, Furnace, Heat Pump. The fan blows constantly no matter which one I choose, and if I turn it off, the furnace turns off. So this is my dilemma; how to I keep the furnace on and the constant stream cold air from the a/c unit off?
I have attached pictures of the thermostat, a/c unit from which the air is a constant flow and the furnace unit.
Thank you,
Thomas V Klusman
03-02-2016, 08:13 PM
Hold on and I will get you the procedure, unless another member who knows off the top of their head can chime in.
Here you go: Post # 5 and 6
http://www.forestriverforums.com/for...elp-46919.html
03-02-2016, 08:22 PM
03-02-2016, 08:29 PM
World Wide Wanderer
Here is the manual for your thermostat. I think if you choose "Fan" then use the "Mode" button it will allow you to change the setting.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
03-02-2016, 08:56 PM
Press the mode button to select FAN then + or - to change it from LO HI or AU
AU is auto which will determine what it needs by whether you have it set on COOL for AC or FURNACE for heat
AC will have cool air come from ceiling vents and FURNACE will have heat from floor vents
Sent from my iPhone using Forest River Forums 🇺🇸
03-02-2016, 10:32 PM
Yep, my thermostat looks the same and works as described here.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
03-14-2016, 10:28 AM
Thanks everybody! I all worked out well thanks to you all.
