Old 12-01-2014, 12:05 PM   #11
Helmsey's Avatar
I have the same issue on my vent hose and I plan on extending it and running it back above the top of the fresh water tank. That should prevent it from siphoning out on its own.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 12-01-2014, 01:09 PM   #12
You should not need to worry about remembering to open the vent tube. The tank should vent through the fill tube too if you are drawing water with the pump.
clarktod is offline   Reply With Quote
Old 12-01-2014, 01:21 PM   #13
Taranwanderer's Avatar
I wouldn't bet on that. You have a screw-on cap on your FW fill, right? If so, that may not let enough air in during use to keep the tank from collapsing under vacuum, especially if it's screwed on tight (which it should be.) I'd still want my vent open. Just add it to your set-up checklist. Checklists are your friend...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 12-01-2014, 02:05 PM   #14
I don't think my fill cap is vented, but that doesn't mean I can't vent it myself - this may be the ultimate solution as the fill cap is well above the tank level... thanks to all... I just need to come up with a way to keep rain water out.
steveh326 is offline   Reply With Quote
Old 12-01-2014, 04:37 PM   #15
I actually have a pressure fill and it does not have a cap so in my case I don't have to worry about the cap. If you have a gravity fill then a cap would cause a problem.
fresh water, tank, vent, water, water tank
