Old 09-27-2016, 03:17 PM   #11
To find the cause, you'll need to crawl around and sniff. I know, not real fun, but it will let you know from where the smells are emanating. We had a toilet with a bad seal on the backside of it. It took almost two days to finally figure that out, and that was only by crawling around and sniffing. I called Thetford and they walked me through some things, gave me an incident number, and said to take ti to the dealer to be replaced.
I also installed the 360 siphon vent caps and I now have absolutely no smells coming into the camper from anywhere, even when I leave the vent open in the bathroom while flushing.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat 4X4 6.4 Diesel
61 nights in 2016
14 nights so far in 2017
ben31 is offline   Reply With Quote
Old 09-27-2016, 04:02 PM   #12
Cypressloser's Avatar
Not the most likely culprit according to your description but still a possibility is the seal between the toilet bowl and the pedestal - not the valve in the bowl. It's an easy fix but not very pleasant as you can imagine.
2013 RAM 3500 Dually Longhorn
2014 Trilogy 3650RL, W/D, Onan 5500, 8000# Axles, IS, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-27-2016, 11:08 PM   #13
We also had this issue with our 2012 Lexington265DS 4 years ago.
Like Hoffwmn did on his Leprechaun, I replaced the vent cap with the Cyclone cap; problem fixed.
I would believe that ben31 solution, using the static 360 siphon vent cap is also a good solution.
In both cases, air passing by is dragging bad odors out.
HerveVR is offline   Reply With Quote
