Old 04-01-2012, 12:17 PM   #1
RoadDog66's Avatar
OEM tires on tow vehicle?
So how many of you are still running the original equipment tires on your tow vehicles when towing your travel trailers? I can't afford to buy new ones yet and hope to keep the current ones as long as possible.
Do you change the recommended tire pressures when towing? Or maintain the OEM recommended limits? I don't think it would be safe to raise the pressure up to the max due to heat expansion under stress when towing, but wanted some opinions.
TV: '15 Ram 6.4 Hemi CC 4x4
Old TT: '12 Rockwood Roo 19 (sold)
New TT: '14 CR Sunset Trail 290QB
WD: Equalizer 1200/12K
BC: Ram OEM
RoadDog66 is offline   Reply With Quote
Old 04-01-2012, 01:12 PM   #2
DF5.4's Avatar
When I had the OE tires on the TV the recommended pressure was 35 psi. Max was 45. These were cold inflation pressures. For trips I would air all up to 43 psi cold. then check them at stops. When taking the TT close like to be inspected I left the tires at the recommended pressure. I did notice that they felt a little squirmy when not aired up.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 04-01-2012, 01:27 PM   #3
I am not planning to change my tires on my tow vehicle. I have the tires that came with the vehicle when I bought it and I have no problems.
capucine is offline   Reply With Quote
Old 04-01-2012, 01:36 PM   #4
Run maximum pressure as listed on the tires sidewalls when towing. Keep the trailer tires at the maximum pressure all the time.
Old 04-01-2012, 02:04 PM   #5
Triguy's Avatar
I changed my truck tires from P-rated to LT-Cs when the OEM tires needed replacing. Its a better tow experience, but I think it make sense to wait until you need the new tires.
I maintain max pressure on both my truck tires and trailer tires when towing - 50psi for all tires. I suppose I could drop the air pressure in the truck tires when not towing but seems like a hassle so I just keep them filled up all the time.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-01-2012, 03:17 PM   #6
Twisty's Avatar
I pumped up my OEM tires to 40 psi b4 picking up the TT. I am going to run 45 psi next time - I think that is the max.
Tire pressures must be set when the tire is cold or ambient temp. - never hot or warmed up from driving.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 04-01-2012, 03:54 PM   #7
cpaulsen's Avatar
I run mine up to 80 when towing on the rears and 65 when not towing.
cpaulsen is offline   Reply With Quote
Old 04-01-2012, 04:18 PM   #8
sherdep's Avatar
I doubt you are running OEM tires unless you are running a 3/4 ton or 1 ton truck with Load Range E tires.
The OP has a Frontier so highly doubt he can be compared to your PSI's.
the OP
changing to a diffrent rated tires (load range) depends on what you are towing and seeing that you are towing a 19 foot ROO - I doubt you will need a heavier load range tires but for piece of mind - look at the side wall of the tire and see what weight they are rated for at what PSI to run them at - I usually run them a few pounds under the max when towing to allow for expansion.
You are going to get alot of diffrent opinions on this one.
the one thing you will notice is when you tow more with P rated tires and not LT's or a heavier load range you will notice the tread is going to wear out faster due to the extra weight.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-01-2012, 05:08 PM   #9
MtnGuy's Avatar
Still running my P-rated OEM tires. When they wear out, I will go with an LT tire.
Old 04-01-2012, 05:34 PM   #10
I switched to Goodyear Wrangler Silent Armor in E range on my 1/2 ton Avalanche and run 65 in rear and 50 up front.
2012 Jayco 33 RLDS
2004 Chevrolet Avalanche 2500
2007 TBSS AWD
Hybrid21SS is offline   Reply With Quote
