03-13-2018, 01:11 PM
#21
That sucks but lucky at the same time. Maybe the extra day out there will be good, you really don't want to rush back to MA right now anyways 3 nor'easters in 2 1/2 weeks.
2008 Dodge Durango retired
2015 Salem cruise lite 195bh retired
2021 Cherokee Grey Wolf 26dbh
03-13-2018, 01:23 PM
#22
Old Engineer
Based on the picture, the TPMS sensor is mounted on a "rubber" valve stem. It needs to be mounted on a metal stem to get accurate temperature measurements.
The rubber stem is a thermal insulator.
03-13-2018, 02:09 PM
#23
Those walk around pay off. Very happy that you caught it instead of on the road. That could of been a real disaster.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
03-13-2018, 02:25 PM
#24
2007 WildCat 32QBBS
Originally Posted by RB19RR
As I look at the wheel and that strange grease pattern....I think it was caused by the hubcap.....before the hubcap was ejected.
The grease must have found an opening at each lug nut recess.
Ahhh. That explanation works for me. Now I can sleep. [emoji106]
03-13-2018, 03:21 PM
#25
As has been said, good catch at your fuel stop, and so fortunate to have quick and easy access for the repair.
03-13-2018, 03:37 PM
#26
Wow, good catch. My wife gets a little annoyed waiting at every stop for me to do a full walk around of coach, toad and towbar. Definitely not going to change my procedures now.
2015 Solera 24r
2017 Jeep Wrangler
03-13-2018, 08:30 PM
#27
If I’m not mistaken, it reads air temp, not valve stem temp. In fact, a metallic valve stem might show a lower temp reading than rubber as it will act as a radiator.
03-13-2018, 08:32 PM
#28
$1400 later....I’m back on the road!
New rear axle, four new hubs, four new sets brakes,a new leaf spring (one leaf was broken) and an extra hub and set of bearings as backup......
Great folks had me in and out in under 5 hours.......
03-13-2018, 08:36 PM
#29
Originally Posted by SpringerPop
Though I have TPMS (a 507), I use it to tell my inflation pressures. I use the temp readouts to tell me the OAT, and which side the sun is coming from.
Given their position, externally, I wouldn't put too much stock in reading a temperature rise of the hub bearings, the rims, or even the internal air temps in the tires.
Remember, that the sensors are simply spinning in ambient air while underway, and that's about all they will reflect, temp-wise.
I have no quarrel with those who expect more, I just don't see much value in TPMS temperature readings.
Pop
It's not reading ambient air temperature. When you put the 507 on the shredder valve it opens the plunger on the valve which allows air from the tire to move into the sensor. Without that air from the tire pushing on the sensor it wouldn't know how much pressure existed. At the same time, it reads the temperature of that same tire air, not the outside air.
BIRDS AREN’T REAL
03-14-2018, 06:01 AM
#30
I'm glad you caught that in time, it could have been a lot worse. Did you buy those lottery tickets yet? Question - there looks like a wedge of some sort between the valve stem and the rim...... never seen one before, but I like the idea. Where did you get that/them?
David and Vicki
19-month-old English Springer Spaniel "Sadie"
2019 Silverado LTZ Duramax
2023 GDRV Reflection 150 226RK
03-14-2018, 06:57 AM
#31
I'm on an epic, two month, cross country trip. Left February 5 from Massachusetts....Took southern route to California by way of Texas, NM, AZ....6000 miles so far....
On my way back east today. Left Oakland CA this AM, got to Bakersfield CA and stopped for gas, did my usual trailer walk around.....UGH!
Blown wheel bearing. But as luck would have it, less than a mile away is a trailer fabrication business and they have a replacement axle, bearings, hub. Will be fixed first thing tomorrow am.
Always an adventure!
THANK GOODNESS you found it when you did!
My only question, how long since you last serviced the wheel bearings prior to that catastrophic failure?
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-14-2018, 07:27 AM
#32
Yeah, like they said go buy a lottery ticket!
I'm amazed the wheel stayed on.
You were probably just moments away from the wheel leaving the axle.
Scary stuff!
Peace!
Dan & Rita D
03-14-2018, 05:03 PM
#33
Old Engineer
The intent is to measure the air temperature of the wheel and tire combination, which tracks the wheel and tire temperature. This is one of the reasons the sensor manufacturer recommends the use of metal valve stems. The temperature measuring element which is part of the pressure sensor chip has to have a low thermal impedance connection to the wheel in close proximity to the tire bead. There is no air or thermal circulation in the valve stem.
03-14-2018, 08:57 PM
#34
The hits just keep on coming! Today, outside Winslow AZ, I lost the rear universal joint on the truck! You can’t make this stuff up. Found a garage that could do it immediately and would let me help. I like doing my own work on the truck. Parts store next door to the garage. Had it replaced in under an hour. Ugh!
To answer the other question. Trailer bearings were serviced in January, before I legt for the trip. Bearings failed because brakes failed, heated grease, boiled it out of the bearings....bearings witjout grease is a bad thing.....I see a disc brake conversion in my future.
03-14-2018, 09:10 PM
#35
2007 WildCat 32QBBS
Man you're rough on equipment! Lol
03-15-2018, 07:38 AM
#36
Where I use to work would call that driver abuse!!!!!!!
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
03-15-2018, 08:22 AM
#37
On 3/2/2018 he posted that he "Buried Both Axles in Sand" at a BLM area and stated he was glad he had 4x4 drive! You ask if he is Rough on equipment! Youroo!!
03-15-2018, 08:39 AM
#38
Before I start, I have amazing good luck with vehicles. Other than a BMW 550i that we bought a couple years ago, I simply don't have car troubles. This truck has 200,000 trouble free miles....Until this week (well, one issue was trailer, not truck)
So, here goes.....I Spent last night at a rest stop on RT40 outside Albuquerque. Beautiful night. Got up before dawn to beat the traffic, made breakfast and headed out. Wasn't a 1/2 mile down the road when I hit a shredded trailer truck tire. Somehow, a piece flew up into the engine bay and damaged the radiator fan and ripped all the wires from its electrically controlled clutch. Sheared off a couple blades! Looks like it didn't damage the radiator. Trying to drive it, the vibration is intense.
I'm on the side of the highway waiting for a tow from AAA as I need to go to a Dodge dealership which is 100 miles away....Too far to limp there.
You can't make this up.......Amazing luck I'm having this week!
03-15-2018, 09:05 AM
#39
A friend of mine calls that 'being snake bit' Sorry for your bad luck. If this is event number three, maybe you're done.
David and Vicki
03-15-2018, 09:07 AM
#40
Whats that old saying?? If I didn't have bad luck , I wouldn't have any luck at all!!!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
