Old 09-10-2011, 03:26 PM   #1
Anders's Avatar
One brake drum getting hot
Hi,
Just recently changed the axle on our 2011 8265 Rockwood and I noticed that one drum heats up way more then the others. I have a Prodigy brake controller and have tried to calibrate but with no luck.... Any suggestions anyone?
Cheers, Anders
Anders Cortes Island, BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab
Harness: Hijacker 24-AS-18 Autoslide, Demco Glide Ride Pin Box
Chuckwagon: 2011 Rockwood 8265WS
Travel Blog
Anders is offline   Reply With Quote
Old 09-10-2011, 05:18 PM   #2
flyrotor's Avatar
Take it to your local tire shop and have them check the brake pads and adjust it for you
flyrotor is offline   Reply With Quote
Old 09-10-2011, 08:43 PM   #3
Bill_C's Avatar
Just sounds like one drum has the adjuster higher than the others. Setting your brake controller doesn't do anything to adjust an individual drum. The controller sends out a regulated voltage, equal for all brake drums. On the other hand, are your other brakes working, or is this the only brake doing a job?
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 09-10-2011, 09:13 PM   #4
Anders's Avatar
Thanks will have it checked.
Travel Blog
Old 09-10-2011, 09:15 PM   #5
Anders's Avatar
Thanks..... The trailer seems to brake good, it is probably like you said that the one drum has the adjusters set up to high.
Travel Blog
Old 09-10-2011, 09:23 PM   #6
Since the axle was just replaced, could be failure to properly pack the bearings. A bad bearing will make the brake drum hot also. Drive careful.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-10-2011, 09:35 PM   #7
Bill_C's Avatar
Good Point !!
Old 09-11-2011, 07:37 AM   #8
MtnGuy's Avatar
Another possibility is failure of the rear seal, letting grease get on the brake pads.
Old 09-11-2011, 07:51 AM   #9
jimh's Avatar
it is more than likely a brake adjustment but i would see if the retainer nut was torqued too tight. i snug mine while rotating, then back off. then tighten by hand then back off 1/4 to 1/2 turn.
this is just another suggestion, the above are good candidates as well.
jimh is offline   Reply With Quote
Old 09-11-2011, 08:11 AM   #10
Anders's Avatar
Thanks everyone...... wealth of information as always. Bearing is fine, grease OK. Will check in with the next tire shop and see if they can have a look
Travel Blog
brakes
