Old 03-08-2015, 06:35 PM   #1
one tire wearing
on my forest river one of my tires is wearing on the outer edge. wheel bearings are ok no excess brake wear any ideas
thanks
gary
locogk is offline   Reply With Quote
Old 03-08-2015, 06:36 PM   #2
oh its a travel trailer
Old 03-08-2015, 06:39 PM   #3
wmtire's Avatar
something may be bent or misaligned. Can you post pics?
2011 Flagstaff 831 RLBSS
Old 03-08-2015, 08:05 PM   #4
WrongWayRandall's Avatar
You may have an alignment issue on that axle. If it is very minor and the tires are likely to age out before they wear too badly rotating the tires regularly may distribute the wear enough to compensate, but it is almost always safer/wiser/better to have the alignment problem sorted out - think safety here, tires are not to be trifled with.
- R
1975 Westfalia (VW)
2014 Rockwood A122
WrongWayRandall is offline   Reply With Quote
Old 03-09-2015, 03:24 AM   #5
Traveling Two
jerryliving's Avatar
We had the same problem. Was told that it was an alignment problem also. Traded trailer before I had to do anything.
jerryliving is offline   Reply With Quote
Old 03-09-2015, 03:25 AM   #6
Traveling Two
Question for wrongwayrandall.....do you rotate front to back or side to side? ??
Old 03-09-2015, 04:18 AM   #7
Witch Doctor's Avatar
Really most people do not rotate trailer tires being there is no drive axle, so anyway would be good. Not like truck tires which is an X rotation.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-09-2015, 05:34 AM   #8
davel1971's Avatar
I had that issue on a Wildwood trailer. Turns out one of the axles weren't in line with each other. The hangers were not welded on the frame properly, causing the axle to be out of line.
David & Lynn
Old 03-09-2015, 07:13 AM   #9
I just took mine in for some warranty work. One of the problems was the right rear tire wearing the outside rib. My dealer said that Lippert has a new axle on the way. It took six or seven thousand miles before it wore enough to be noticeable. I have a tpms and I noticed that tire usually ran a little hotter than the others. If you are out of warranty you could just take it to an axle and frame alighnment shop.
comfun1 is offline   Reply With Quote
Old 03-09-2015, 07:18 AM   #10
We only have two tires on our camper, and I don't rotate them (they will very likely age out before they wear out), and I'm the sort that would get the alignment fixed rather than move the tires around, but if you were so inclined, rotation pattern usually is not that critical so long as the interval and pattern is always the same. That said, if the alignment issue too bad all you are going to accomplish is to ruin all of your tires.
Can you post a picture of the wear pattern? Is it worn on the inner or outer edge only? If so it it evenly worn all the way around or do you have scalloping in the tread? Is only the center worn? The wear pattern will tell you what type of issue you have, and if you are lucky it's down to tire pressure (center-only wear is often over-inflation, both inner and outer edges worn often under-inflation) but if that's all it is you should know already (because you do check your tire pressure before you head out each time, right?)
- R
1975 Westfalia (VW)
2014 Rockwood A122
Old 03-11-2015, 05:51 PM   #11
what pictures do you need
Old 03-11-2015, 06:19 PM   #12
Side view of problem side of trailer and tire. Front or rear view of tire, picture of the axle with suspension of bad tire.
Old 04-01-2015, 09:19 AM   #13
Starboard's Avatar
Alignment. Get your tires aligned.
Starboard is offline   Reply With Quote
Old 04-01-2015, 09:33 AM   #14
How do you align tires?
tire
