Strictly speaking, yes; the coax cable used for the "Cable-In" connection is suitable for OTA television. Of course, you will have to connect your Television to the "Cable TV" connector and NOT the roof antenna connector on the inside.
Looking at the "typical" factory installed antenna, you will probably find the normal "F" type connectors at the antenna head, and possibly where it goes "into" the roof so these could also be options for you.
The "F" connector on the roof, of course, is a likely place for water intrusion so be appropriately cautious.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
